View topic - NJ pajero oil change
• Page 1 of 1
HI guys
i have a 1995 nj gls 3.5LTR pet pajero and want to change the oils in both front and rear diffs plus gear box diffs have LSD in them too i just wanted to know if anyone knows how much oil each one takes and whats the best oil to use for the job.thanks for any help guys
see you around the bush somewhere with a nice cold beer
chhers ty_83:):truck:
The owners manual for a 1999 NL lists the following (I can't see a 1995 model being that much different)
Manual transmission 3.7l of Hypoid gear oil API GL-4, SAE 75W/85W, 75W-90 or 80W.
Transfer case 2.5l of Hypoid gear oil as above
Front diff 1.2l of Hypoid gear oil API GL-5 or higher, SAE 80W-90
Rear diff (limited slip) 3.2l Castrol Hypoy LSX90
Hope this helps
Cheers Vaughan.
Hope this helps
Cheers Vaughan.
This is from the Penrite oils web site
Make MITSUBISHI (AUS
Model Pajero NJ 3.5 V6
Engine P
Year 1993 - 1996
Application Recommendation Capacity (ltr)
Engine (P) First Choice HPR 10 (a) 4.9
May also Use HPR 15
Manual Transmission SIN Manual Trans 3.7
Automatic Transmission ATF DX-II 8.5
Differential First Choice Limslip 90 3.2
May also Use SIN Gear 75
Coolant Premium AF/AB 9.5
Transfer Case SIN Manual Trans 2.5
Front Differential First Choice Hypoid 80W-90 1.2
May also Use Transaxle 75
Engine P
Year 1993 - 1996
May also Use HPR 15
Paj4X4 wrote:Engine (P) First Choice HPR 10 (a) 4.9
May also Use HPR 15
Last change I used Penrite Full Synthetic 5w-50.
As the book says 20w-50, would the thicker oil in there at the moment do any harm?
NH Pajero 3.0 V6 Auto GLX, TJM Bullbar, Side Steps, LOVELLS Gas Legend Series II Shocks, Spotties, 40L Primus fridge, other stuff to come......
• Page 1 of 1
Who is online
Users browsing this forum: No registered users
