How do you know your steering dampers still work?
Springs, shocks and all things between your chassis and diffs
98fex
Unread post by 98fex » April 9th, 2019, 9:23 pm
how do you know when/if they are still working?
hoyks
Re: How do you know your steering dampers still work?
Unread post by hoyks » April 12th, 2019, 7:04 pm
Disconnect one end, mark and loosen the return to centre spring if it has one, and push/pull on it to see if its dampening evenly in both directions. If it has an eye bush at one end it will help as then you can stick a socket extension in there as a handle.
I had one fail so it had no resistance/dampening in one direction and it made for some interesting handling on a potholed road, the bumps pulled the steering wheel from my hands and each hit just about turned my sierra into the trees.
98fex
Unread post by 98fex » April 15th, 2019, 8:09 pm
Thank you that
98fex
Unread post by 98fex » April 15th, 2019, 8:10 pm
Thanks for that
Return to “Suspension”
