Greasing of UV joints/ Drive shafts
arief
Unread post by arief » November 17th, 2018, 1:57 pm
How often do you guys grease the universal joints on the drive shaft?
hoyks
Re: Greasing of UV joints/ Drive shafts
Unread post by hoyks » November 17th, 2018, 2:29 pm
I used to do mine when I did an oil change or had been playing in water.
The uni joints I'd pump full until I could see grease being pushed out.
The slip yoke on the shaft only gets 2 or 3 pumps of grease. If you pump it full the extra grease can form a hydraulic lock and the shaft as well as bits at either end can be damaged.
arief
Unread post by arief » November 18th, 2018, 10:43 pm
thanks hoyks. Yeah i read about the slip yoke. its suppose to have a bit of play/ flexibility.
my 3.0 litre Auto Everest goes through a uni joint change at least once every 12 months. but i have not bothered to grease the unis as hardly go offroading/ or play in the water.
