PA2 Challenger Horn fuse - where is it?
Scootymad
Unread post by Scootymad » October 20th, 2018, 2:14 pm
So I was a muppet the other day and hooked up an air horn to the stock horn wiring. Sure enough the horn no longer works. Went scratching around for the horn fuse but I'm buggered if I can find it or any other fuse box other than what's in the engine bay. I don't even know where the relay is on mine. If it helps, mine is a 2000 model 4M40T powered auto.
Next time I'll be using a relay and wiring it up properly. It sounded like a train until it conked out :lol:
Scootymad
Re: PA2 Challenger Horn fuse - where is it?
Unread post by Scootymad » November 14th, 2018, 4:47 pm
Never mind, found the fuse box in the deepest darkest corner of the driver's footwell. Rewired it properly with a new relay and used the existing horn circuit to trigger the relay
Return to “Challenger”
