Guss' VX 2016 200 Series - Mods Pics & more
Guss
Re: Guss' VX 2016 200 Series - Mods Pics & more
Unread post by Guss » November 22nd, 2016, 7:34 pm
Agree BigD, very well layed out dash, Nav could be better apart from that very comfortable on & Off road.. ;)
viewtopic.php?f=187&t=160755
viewtopic.php?f=187&t=34585
Guss
Unread post by Guss » December 17th, 2016, 12:23 pm
Finally got the Cruiser up into the Vic High Country to test out the Traction & Crawl Control systems..
Crawl Control:
I have to admit 1st up looking down Steep track.. Turning centre diif lock Off putting into D, (Drive Auto), hitting the Crawl Control button * taking the foot off everything had me tighten the butt cheeks! Just goes against the grain! Anyway it works but going down it makes one hell of a racket & I can see it would be hard on the brakes.. Stopping, reengaging the centre Diff Lock & putting in low 1st saw it walk down with no issues so for the life of me can't see why you would use going down hill.. Up hill different matter absolutely brilliant & will use it without hesitation.
ImageUntitled by Gus Davis, on Flickr
Video testing On Burgoynes Track:
Traction control:
This being the 1st 4WD I've owned with it, I can say I can't see why others have complained about it, (I can only think that for it to be an issue tyre pressures may not have been right), I always air down off road to about 20PSI & will go lower if required, I found the Cruisers traction control brilliant & only noticed it on a few occasions via a flash or click..
Guss. ;)
Guss
Unread post by Guss » March 8th, 2018, 3:07 pm
Just fixed pics back up using Flickr..
Been a while since I've update. Removed the Flashlube Catch Can & Replaced with a Provent200 after finding out it's a rebadged Provent100 & according to their specs rated to 100kw.
Also after doing all the Calcs & not doing a GVM upgrade my lovely wife decides time to upgrade the Off Road Van so sold the TJM Gold Series & fitted Lovells 3800kg GVM upgrade:
Also Added a UniChip Wow unbelievable difference 5Map settings live tuned... I can't wipe the smile of my dial.
Guss.
Guss
Unread post by Guss » March 8th, 2018, 3:24 pm
The Unichip is fantastic On & Off Road, Towing our New 3 Ton fully Loaded Off Road MDC XT17T is incredible power is at hand if needed & not that I'm overly concerned economy was surprising on our last trip to Omeo averaged 17.5 going & 16.8Litres per 100ks on return trip.
Here's the new Van:
Some Pics from Omeo area:
Guss.
Mulder030
Unread post by Mulder030 » April 22nd, 2018, 6:37 pm
thats a cracker of a set up Guss!
Unread post by BigDutchy » April 23rd, 2018, 7:43 pm
Hey Guss you should wear sunglasses too mate!! ;-)
ian.gonzo
Unread post by ian.gonzo » April 25th, 2018, 1:14 pm
Flash bit of gear, The old saying that a master looks like his dog is true, can't work out which is the boss though.
Unread post by Peter Aawen » April 25th, 2018, 1:23 pm
Flash bit of gear......
.....can't work out which is the boss though.
It IS a very flash bit of gear - the whole outfit!! And having seen it close up, it just makes me even more jealous than the pics do!! :o
As for working out which of those two is the boss, it only takes a very short while of watching them both together to work out which one actually rules the roost!! :p :lol:
Unread post by BigDutchy » April 27th, 2018, 4:53 pm
Just lock both up in a warm room for 5 minutes. The one that loves you when you open the door is the dog..... ;-)
The one that will make you run is the other one....
Guss
Unread post by Guss » April 29th, 2018, 12:24 pm
Hahahaha :lol:
Yea ok Jasper is better lookin' than me & on walks he pulls the Young ladies over to pat him which I have no problems with :cool:
Just for you DigDutchy...
Unread post by BigDutchy » May 5th, 2018, 8:34 pm
Great photo!!
Boxers are a bunch of silly fun. I really like them.
