for the snorkel:
1x 3m length of 90mm pipe
http://www.bunnings.com.au/holman-90mm- ... e_p4770094
1x pack of 20mm tek screws
http://www.bunnings.com.au/zenith-12g-x ... k_p2420336
1x pack of 90mm downpipe clamps (the clamps with legs cos you will be bending them to suit)
http://www.bunnings.com.au/kinetic-90mm ... k_p4920094
silicone to seal and pvc glue to fix
now... the fittings (I will do my best to get this right for you, I made about 6 trips to bunnings just to play around with different angled fittings... I didn't want to buy 10 of each to start with lol)
1x 80mm-90mm straight coupling (this is for the airbox adaptor)
can't find a link for this? but I did pick it up at bunnings...it was a misplaced item just randomly lying on a shelf in the plumbing section??
3x 90mm 45deg male/female
http://www.bunnings.com.au/holman-90mm- ... w_p4770313
2x 90mm 45deg female/female
http://www.bunnings.com.au/holman-90mm- ... w_p4770211 ...disregard the picture, it's incorrect.
2x 90mm 22.5deg male/female
http://www.bunnings.com.au/holman-90mm- ... w_p4770312
1x 90mm 22.5deg female/female
http://www.bunnings.com.au/holman-90mm- ... w_p4770309
1x 90mm 90deg male/female
http://www.bunnings.com.au/holman-90mm- ... w_p4750159
http://www.bunnings.com.au/holman-90mm- ... w_p4770310 ...again, the picture is wrong
1x 90mm mosquito screen.
http://www.bunnings.com.au/rain-harvest ... n_p4815249
I did buy some 15 degree bends as well, but I don't think I used them.
this is the order I used the fittings in, starting at the airbox and working back (notice the orientation of the 'm' and 'f' representing which way the fitting was used. I only used one back to front at the very end of the snorkel because the 90deg male/female fitting has an extra bulge in it for some reason, this made it stick out further and didn't look too nice, so I used a 45deg male/female back to front so that I could use a 90deg female/female for aesthetics)
80-90mm straight adaptor into- 45m/f- 22.5m/f- 90m/f- long straight section of pipe- 45f/f- 22.5m/f- 45m/f- medium straight section of pipe- 45f/f- short straight section of pipe- 22.5f/f- long straight section of pipe- 45F/M- 90f/f- mosquito screen.
I had a bit of 25mm flat galv laying around which I used to make a sturdy bracket at the top. general tools you will need are measuring tape, masking tape to hold pipes in place, permanent marker to mark the orientation, drill and drill bits, hammer, and vice, grinder, hacksaw, holesaw, zinc paint to prime the exposed steel...so on so forth. OH! and a stovetop to make the indent for the indicator clearance on the first 90deg bend...mine's electric but it still worked, just put a bit of baking paper down first LOL!
I glued 90% of the joints and siliconed 3 so that the snorkel can be removed if need be. I siliconed the joint coming through the exterior guard, the 90deg elbow going through the inner engine bay panel, and the adaptor into the airbox. everything else was glued. and a word of warning when glueing them together... do it quick! the pvc glue sets extremely quickly and it threw some of my lengths out a little because instead of seating against the lip inside the fitting, it got stuck/set, 1/2 - 3/4 of the way in. have a rubber mallet handy, line it up, and smash it on! I gave mine a light sanding and painted it matt black at the end. I used rust-oleum because it sticks to pvc the best apparently.
that should be enough info to get you by for now...if you need anything, hit me up.
92' 4runner, 3.0Loser manual. Custom DIYPVC snorkel. ISR mod. Hurricane headers with 2.5" exhaust, stainless 200cpsi cat and turbo muffler. TJM bullbar with hella spotties, LED indicators. 2" body lift. 15x10's 0 offset chromies, 31x10.5 a/t's. FlameThrower injectors, 7mge vafm upgrade with modified cressida airbox for snorkel, 7mge coil upgrade. Plugs gapped to 7mge specs (1.1mm). Eagle 7mm spark leads. Aftermarket a-pillar oil pressure and water temp gauges, rear Aussie Lokka
