Wierd goings on... 4x4 & 4L lights staying on! Any ideas?
suzygs1000
Re: Wierd goings on... 4x4 & 4L lights staying on! Any ideas?
Unread post by suzygs1000 » July 19th, 2018, 7:00 pm
Hi, Guys,
I recently experienced this problem in my PJ Ranger with 149 k's on the clock.
After reading through this, I searched on Ebay for the Transfer Case module.
There are a number of them listed, ranging from $1800 to $225. Being a tight arse, I purchased the $225 one, which was listed as a Great Wall part.
The unit fitted perfectly, all wiring was correct, and the job took about an hour altogether.
It fixed the problem.
I pulled the original item to pieces, as it is a sealed unit, I had to wreck it to get at the switch. Inside, there is what appears to be a fibrous washer over the shaft which fits into the gear.
This fibrous washer had come to bits, and there were bits of fibrous matter floating around everywhere, including under the sensor strips.
I have taken a photo of the failed part, but cannot see how to post the photo.
Anyway, if any one suffers this problem in the future, don't muck around with electronic modules or relays, just replace the transfer case module.
I also noted that someone had purchased one for about $70 from Aliexpress.
The module is identical to the Borg Warner item, but has a slightly different brand name, which I cannot recall at the moment.
regards Dave.
suzygs1000
Unread post by suzygs1000 » July 19th, 2018, 7:01 pm
Obviously, I worked out how to post pics ....
arief
Unread post by arief » September 10th, 2018, 7:33 pm
HI Suzygs1000,
do you mean, you replaced the transfer case 4X4 Shift Motor?
Robbieraven
Unread post by Robbieraven » November 14th, 2018, 7:44 am
Hi Guys,
For Dr Fleetwood (Rob) mainly :) Hope he is still on the forum.
Just bought a 2007 Ranger PJ 5 Speed Auto about a month ago, all in great condition but the previous owner was good enough to say: "there is a weird thing that happens every now and then" yes you guessed it :)
Anyway, had no issues in the first month, until yesterday. Yep, low 4 light comes on and speedo freaks out. Have done a bit of mechanical bits in the past but I did think this was weird. Ah well speak to Google and I was so surprised to find this thread with all the exact symptoms. Any got hold of a T15 bit and turns out it was a T30 that was needed for mine, I loosened and adjusted the offending plate as described by Rob (by fleetwood » May 30th, 2015, 5:48 pm)
Bang the light, went off, am off to do a road test in a while but thought I'd report back so far. As far as I could tell the plate on mine seemed to be plastic but I didn't remove it fully, just moved it within the slots. All good so far, so i too said something like: "This guy is a legend" thanks Rob
I'll keep you posted guys.
Cheers Rob (2)
Robbieraven
Unread post by Robbieraven » November 14th, 2018, 8:39 am
Ok all good so far guys, thanks again Dr Fleetwood
fleetwood
Unread post by fleetwood » November 15th, 2018, 9:46 pm
Hi Robbie...
Yep still pop in from time to time..
Good to hear the quick fix worked for you... If the problem becomes really persistent you can dismantle & clean the offending parts... I haven't needed to so far. Just make sure you always have that torx driver with you LOL
Cheers for the thank you
diemonty
Unread post by diemonty » November 21st, 2018, 4:42 am
Finally fixed by buying online from aliexpress 80usd delivered.
search "Transfer Case Shift Motor for Great Wall Hover Wingle X200 V200 X240 H3 H5 for Mazda BT50 2006-2011 UN model Automatic 4WD "
not worth opening the old one.
arief
Unread post by arief » November 24th, 2018, 2:28 am
HI Diemonty,
im having the same problem, been driving around without 4wd option and various workshops around Kuala Lumpur Malaysia cant pin point the exact problem. thinking of just buying the transfer case shift motor.
went on Aliexpress after reading your posting and found this:
https://www.aliexpress.com/item/Transfe ... e4aec74862
you'd be doing me a big favour if you can go to the link and have a look at the item if its the correct one.
Thanks mate.
cheers.
diemonty
Unread post by diemonty » November 25th, 2018, 5:35 am
Hey Arief
It is the same part just from a different seller, even though they used the same stock photos'
It's no longer 80usd must have been 11.11 sale or something..
best wishes.
arief
Unread post by arief » November 30th, 2018, 12:33 am
Hi Diemonty,
cheers mate. I'm gonna proceed to purchase this from AliExpress. The autogearbox specialist who just rebuilt my gearbox (refer to my reply to you in a different thread) confirmed that this is the faulty part. Said If i buy it off AliExpress he can install it for me. We checked from the official Ford spare part dealer in Malaysia, the original part cost MYR2,200 (approx. AUD700 at current forex rate). bloody expensive!
diemonty
Unread post by diemonty » December 1st, 2018, 5:42 am
I'm glad to hear this will save you money arief. I can't believe the dealers here wanted $1800
It really is easy to install; the hardest part was getting the electrical plug and socket to come apart.
Less than ten minutes if you have the socket set ready.
Cheers mate
Return to “PJ/PK Ranger / Old BT50”
