Questions that need answers!
Shann Low
Re: Questions that need answers!
Unread post by Shann Low » March 14th, 2016, 12:58 am
How do you tell when someones dead? Answer = no pulse..
So death certificates usually list causes of death as myocardial infarction... or the heart stops beating - in the common vernacular, = died of heart attack!.
So no one dies of old age - they die of "heart failure". Old age may well cause the heart failure - but it's not listed that way on death certificate by the presiding doctor.
Just more of those weird taboo subjects no one ever talks about!
buffer
Unread post by buffer » March 14th, 2016, 4:24 pm
Simple everything has an expiry date and a cause or fault: for example
Take an old vehicle it's not the age that gives up it's an old very worn out motor or the red metal (rust) so the cause of death is not age it's the motor fatigue or no body due to rust.
So if we serviced our bodies we would most likely last for ever, but we need to put a cause of the problem.
TLC60S
Unread post by TLC60S » March 15th, 2016, 9:18 pm
The answer to RODEODAVE question is 1 day old going from when I have been visiting old historical mining grave site cause
back then life was harder you read the head stones saying died at birth with the youngest saying died one day old.
Cheers TLC60S
jfoldbar
Unread post by jfoldbar » March 25th, 2016, 12:05 pm
why does one ton of gravel on my trailer make the tyres flatter than one ton of tree cuttings?
a guy i know reckons its cause one ton of gravel is actually heavier than 1 ton of tree clippings. but since both weigh the same on weighbridge than how can it be different?
the-viking
Unread post by the-viking » March 25th, 2016, 12:43 pm
Earth, rock, soil etc effects the molecules structure in rubber based items like tyres. The molecules spread from each other causing the item to become more supple. In the case of a tyre it would appear to look flat. Flora has no effect on the molecules in rubber………………………. :)
Actually I wouldn't have a clue. I just made all that up…... :D
Well actually I have a theory though. Gravel being more compact distributes it weight more evenly over the axle and hence the tyres. Foliage is all over the place in the back of a trailer with heavier bits here and lighter bits there. If thats not right default to my made up one….. :thumb:
stockhorse
Unread post by stockhorse » March 25th, 2016, 6:08 pm
jfoldbar wrote:why does one ton of gravel on my trailer make the tyres flatter than one ton of tree cuttings?....
It doesn't! :frog:
TLC60S
Unread post by TLC60S » April 2nd, 2016, 1:05 pm
The one ton of gravel would have been spread evenly in the trailer distributing the weight evenly over the trailers axle where the tree cuttings weren't cause trees cuttings are light compared to gravel until you are carrying one ton of each .
So my guess was the tree cuttings was loaded more to the front of the trailer which had the tow vehicle sharing the loads weight.
Cheers TLC60S
MudChaser
Unread post by MudChaser » April 18th, 2016, 3:28 pm
What happens when you get scared half to death twice?
"What we are never changes But WHO WE ARE NEVER STOPS CHANGING!"
Doug Stanton
TLC60S
Unread post by TLC60S » April 18th, 2016, 5:35 pm
As long as there is a gap between being scared half to death each time you will be OK . Your heart stops but not long enough to be classed as clinically dead.
You are lucky cause in this instant two halves don't make a whole.
Cheers TLC60S
jfoldbar
Unread post by jfoldbar » April 18th, 2016, 6:31 pm
TLC60S
How long (or wide) does the gap have to be? 10 minutes or 5 days? Or the size of my mother in law?
I got scared half to death once. So I guess that means I only have 1 more left? But then I was thinking maybe I was only scared 48% to death, so I should be right with one more scare...
TLC60S
Unread post by TLC60S » April 18th, 2016, 7:43 pm
No it's okay to be scared half to death more than twice cause two halves don't make a whole.
Cheers TLC60S
blutoy
Unread post by blutoy » April 19th, 2016, 7:13 pm
if poisons, go out of their "use by date"
do they become more poisonous ? or less poisonous ? :crazy: ;)
TLC60S
Unread post by TLC60S » April 25th, 2016, 8:56 pm
More poisonous because they become unstable after time & the residue remains.
TLC60S
Unread post by TLC60S » April 25th, 2016, 9:00 pm
To all that may read any of my post in this thread for safety reasons
DONT BELEIVE A WORD I SAY.
Cheers TLC60S
jfoldbar
Unread post by jfoldbar » April 27th, 2016, 5:00 am
TLC60S
I'm not sure if that ^^ is a question, answer, or rant.
But here's my question, I've been pondering since the long weekend.
Why can't some dog owners understand that not everyone is a dog lover?
