Ask for/Recommend a 4WD Mech/W-shop - Quick Search
Anything and everything in the world of 4WDing & Fourby's; if it's 4WD related & not covered by a specific section elsewhere, then put it in here!
camelpromo
Recommend a Reliable Mechanic, Eastern Suburbs Melb?
Unread post by camelpromo » March 23rd, 2014, 9:58 am
I've had a quick search and couldn't find anything, and I think this is the right spot but please move if it isn't.
My father has had perpetually s--thouse luck with bad and dodgy mechanics (out of pocket well over 10 grand, unfortunately my dad is very polite and won't fight back when faults happen for blatant poor workmanship), so I am hoping someone can recommend a decent mechanic in the mt waverley/chadstone/oakleigh/camberwell and surrounding suburbs areas.
The car is a 1st gen Ranger, so probably a dedicated 4x4 mechanic would be the best place to find, but we want someone that will actually check the book and follow what has to be done, but also use common sense and grease uni's, adjust handbrake, check diff oil level, etc. Stuff that isn't in the book but should be checked/done anyway.
Thanks in advance!
CurtGQ
Re: Recommend a Reliable Mechanic, Eastern Suburbs Melb?
Unread post by CurtGQ » March 29th, 2014, 9:54 am
Gday mate, i may be a bit biast in what im a bout to suggest because of where i live, and i appreciate it may be out of the way, but bayswater, and coolstore rd croydon has a pleathera of specialised 4by services,anything that can be done and thought of will be found up here, be it that we are so much closer to tracks out here and theres a higher demand im not sure?? but there are some real talented mechanics out this way. Hope that helps mate,all the best.
airman08
Recommend a workshop for clutch replacement in Melbourne?
Unread post by airman08 » April 10th, 2014, 12:24 am
Any good place to recommend for my HZJ105 clutch replacement?
xgrumpig
Diesel mechanic
Unread post by xgrumpig » April 14th, 2014, 12:44 pm
Gday guys just recently moved to Dungog nsw
and I need to find a diesel mechanic to get the old girl fixd can anyone suggest one cheers
1997 Ln106 Trayback
Au falcon ghia seats
2" toughdog up front new
2"load carrying old man emu in the rear
2"body lift
33's
soon to be fully engineerd.
http://www.4wdaction.com.au/shed/classi ... -rockyscat
jacnden
Recommend anyone in Western Melb for custom fabrications?
Unread post by jacnden » April 15th, 2014, 4:10 pm
hi all
I have used creative offroad fabrications in hoppers crossing for lots of mods to front and rear bars, sliders, dual batteries, suspension and lots of other stuff. found luke and bec great to deal with.
only problem is they have moved to queensland !
does anyone know of someone in western Melbourne that does custom work , welding, and just 4wd mods?
chris_stoffa
Location: Wandering in the Wilderness of the Western Burbs of Melbourne., VIC
Re: Recommend anyone in Western Melb for custom fabrications
Unread post by chris_stoffa » April 16th, 2014, 5:15 pm
Try having a chat with the guys down at Western 4WD opposite the Hoppers shopping centre
They are always very helpful and may know a custom fabricator
03 Bravo 2.5TD DCab
jacnden
Unread post by jacnden » April 16th, 2014, 8:56 pm
they used to do a bit of work themselves but are now a ARB store and dont do any custom stuff, but they may know someone, i will keep them in mind
Symster
Unread post by Symster » April 17th, 2014, 11:12 am
Mate a couple places come to mind:
- 4x4 Obsession in Melton (http://4x4obsession.com.au/)
- Extreme 4x4 in Hoppers crossing (http://www.extreme-4x4.com.au/)
You can also try Werribee Exhausts - they do a lot of work on 4wds - I've used them before and they were pretty good and a mate of mine got some rock sliders fabbed up for his GU by them. (http://www.werribeeexhausts.com.au/)
Hope that helps.
jacnden
Unread post by jacnden » April 17th, 2014, 12:35 pm
thanks for that, I know both the hoppers places ,I will make some enquiries.
I did think extreme was just a mechanic and the other just exhausts. while I was searching I did find that melton website but it doesn't say much
It will give me somewhere to start :)
malex
Servicing in Perth
Unread post by malex » April 18th, 2014, 11:35 pm
hey guys
about to buy another 80 series diesel… its got around 300 000kms on it so wouldn't mind getting it serviced by a mechanic…
usually do oil and filters myself but yeah just want her to mickey mouse from the get go!
where do you guys get your car serviced in north suburbs perth?
malex
Re: Servicing in Perth
Unread post by malex » April 18th, 2014, 11:39 pm
any mechanics out there- what does a major service include apart from oil and filters?
Rogers Cruiser
Unread post by Rogers Cruiser » April 19th, 2014, 12:05 am
Oil and filters is a minor service, A major service could include anything from transmission fluid, transfercase fluid, diff oils, front and rear bearings, unijoints, timing chain ect.
New car for me means, all new filters, all new fluids, check all bearings, unis ect. assuming the bearings ect pass then it will cost you a few hundred $$$$.
evaredy
Unread post by evaredy » April 19th, 2014, 11:18 am
I get my Dmax serviced by Robson Brothers in Welshpool.
http://www.robsonbros4wd.com.au/
They aren't the cheapest but they are very good.
jacnden
Unread post by jacnden » May 2nd, 2014, 4:48 pm
well it turns out Werribee exhausts does do some of the work I want, thanks for that
taking the car in tomorrow to see how it turns out
Symster
Unread post by Symster » May 2nd, 2014, 5:06 pm
No worries - let us know how it goes.
Return to “Anything to do with 4WD's &/or related to Fourby's”
