buying used' MK
buying used' MK
Unread post by bp1495 » February 28th, 2013, 8:03 pm
Hi all, just wondering if there are any Triton specific problems i should look out for when looking at a Mk triton, thanks
MK tourer
Re: buying used' MK
Unread post by MK tourer » March 3rd, 2013, 9:36 am
Hi, I have had mine since new, a 2005 model, Auto front hobs are a problem, If your lookin at an earlier model with manual hubs , then you'll be right.
If your looking at a 2.8 lt diesel engine, I've heard others having troubles with oil pressure and switches.
Tailshaft centre bearings are an issue with these .
The only other checks would be the usual ,rust, Spring Shackle pins. If it has a bullbar you might find Sagged torsion bars up front.
I hope this helps
Return to “Triton”
