Just finished 3.5ltr into mk conversion
Mitsman
Re: Just finished 3.5ltr into mk conversion
Unread post by Mitsman » May 12th, 2012, 8:26 pm
Getting about 500k's per tank atm
175kw 6G75 Converted = Fun
Mickthesparky
Unread post by Mickthesparky » February 12th, 2013, 3:29 pm
Anyone know who does this conversion in the eastern states? I am in Qld. I would like to drop in the 3.8 if possible
Oul-053
Unread post by Oul-053 » February 17th, 2013, 6:51 am
I did the 3.5 conversion and live on the gold coast if thats any help.
barron67
Unread post by barron67 » February 22nd, 2013, 4:08 pm
Fantastic conversion, job well done by the sound of it.
I have a few questions for anyone who might be able to help.
I have just purchased a 2001 mk triton with the 3.0 v6 and auto and only 140000 K's and front/rear ARB diff locks, i'm very happy with the vehicle overall,but having been a manual gearbox driver all my life i would prefer to convert it, if possible.
If i did change the gearbox to a manual will the diff ratios be out of whack?
Can i do the 3.8v6 magna conversion with the auto? (if the manual is out of the question)
Or perhaps you might have a different suggestion
Also i'm finding the front brakes a bit inadequate, has anyone upgraded them?
Thank you in advance.
Mitsman
Unread post by Mitsman » February 24th, 2013, 10:44 pm
G'day
A manual conversion would be possible but would be a fair bit more work, if you'v driven a manual all your life you will soon learn that an auto is better up the bush :)
With the brake's i know the earlier MK's had single piston callipers, mine's an 03 and has twin piston, im not sure on the disc size though, should all swap over pretty easy id say!!
barron67
Unread post by barron67 » February 25th, 2013, 5:15 am
Thanks Mitsman, i'll check the brakes out.
wizardry
Unread post by wizardry » March 8th, 2013, 4:21 pm
i was just reading through this thread and was wondering whether there would be much of a difference to do this with an mj triton.
and if some one could send me some pic on the mods as im thinking about doing this my self as th mj has 400+thousand ks on it.
Mitsman
Unread post by Mitsman » March 12th, 2013, 5:44 pm
Not sure on the MJ, Are the the 12 valve 3ltr? if so you might have some luck with the older DOHC 3.5 from the pajero's? or you could use the same 3ltr from the tr/ts magna, should be a straight forward swap
pickle
Unread post by pickle » March 12th, 2013, 6:34 pm
MJ are 3 ltr 12 valves. Triton MK/Challenger PA models run the 3 ltr 24 valve. Basically both 3 ltrs run the same blocks just pistons and head/ cam differences. You will also find the when the 3.5 was dropped into the Pajero they needed a bodylift of near two inches to fit the larger transmissions in . So if you want a swap a 3.5 into your MJ you need to check the transmission will physically fit.
I don't think the motor would be the major problem!
Dave
pickle
Unread post by pickle » March 12th, 2013, 6:58 pm
barron67 wrote:I have just purchased a 2001 mk triton with the 3.0 v6 and auto and only 140000 K's and front/rear ARB diff locks, i'm very happy with the vehicle overall,but having been a manual gearbox driver all my life i would prefer to convert it, if possible.
Now thats interesting. An auto 3ltr MK Triton. Thought they were all manuals until the 3.2 diesel jobbies.
Dave
Oul-053
Unread post by Oul-053 » March 12th, 2013, 7:55 pm
plus the dohc model engine will require complete rewire for the dohc ecu and dash etc, way too hard. just go the 3.5 sohc im loving mine, even running 33's it will spin tyres...
The auto will bolt up fine as my 3.5 was from an auto magna and bolted up to my manual gearbox perfectly. the blocks dont change between auto and manual engines.
barron67
Unread post by barron67 » March 19th, 2013, 7:00 pm
Oul-053 wrote:plus the dohc model engine will require complete rewire for the dohc ecu and dash etc, way too hard. just go the 3.5 sohc im loving mine, even running 33's it will spin tyres...
Ooh goody! thanks mate.
barron67
Unread post by barron67 » March 19th, 2013, 7:23 pm
Dave[/quote]
Yep, original equipment it is, just in the process of making an aluminium canopy/tray for it too.
wizardry
Unread post by wizardry » April 3rd, 2013, 7:29 pm
does anyone know if the 3.5 sohc head will fit the 3.0 block if so what mods
:confused:
Mitsman
Unread post by Mitsman » April 3rd, 2013, 7:47 pm
Depends on which 3ltr your talking about, if its the 24v sohc then yes there a straight swap. You just need to be careful some heads dont have a place to bolt on the cam angle sensor so you'll need to make a bracket
Return to “Triton”
