- Here and there
Re: Wheel Sizes???
Slightly off topic, I was sitting out on the veranda the other day just watching the world go by and it struck me that 7 out of 10 4wheel drives that went past, I swear I could hear them coming from half a mile away.
What is the noise like from within the car, it must be unbearable.
I have standard Nexen A/T's on mine and they seem pretty quite to me
Regards
Rich
Rich
- Need to get out more
Re: Wheel Sizes???
It's not bad at all. More noticeable outside the car for sure.
You do notice it at first when you get your first set of muddies but you get used to it and it just becomes normal. Some tyres are worse than others too, especially at different stages of wear.
Nathan
Nathan
- Avid Poster
Re: Wheel Sizes???
I once had a test drive in a Pajero that had AT tyres and they were incredibly noisy.
I mentioned this to the mechanic who did the inspection and he had also picked this up. Apparently as tyres start to age the rubber becomes harder and much more noisy. From memory this only becomes a problem after say 4-5 years - but if your 4by is only doing the school run 4-5 years should be no problem I'd think. Might explain some of the noise you're hearing?
Sam
Sam
1999 Challenger, with Dual airbags and LSD
Mods: Does a roof rack count?
- Here and there
2014 Challenger ATs?
Hi all,
Some more newbie related questions from me. I originally sought advice on an MUX vs Challenger and choose the Challenger :-) I've also asked some general recovery questions in the general forum.
Fingers crossed I'll be picking up my new Challenger this week. Just waiting on the tow bar, bull bar and snorkel to be fitted.
The stock tyres on the vehicle are highway Duellers 265/70R-16. I'll want to add some ATs sooner rather than later.
Specifically tyre related I wanted to check if fitting tyres with minor changes in width and profile have any detrimental affect on the vehicle. For example Micky Thompson ATZs come in 265/75R-16 while Coopers AT3's come in the stock size their ST-Maxxs come in the same size as the Micky's.
My tyre research has not extended beyond that at this stage. Will be very happy for advice on brands etc.
Most of my driving in the immediate future will be on in Sth NSW/ACT and NSW/VIC high country. Mid to long term road tripping this country of ours towing a camper trailer is on the cards.
M
M
- Here and there
Re: 2014 Challenger ATs?
I'm looking at fitting Maxxis AT 980's. They come in the stock tyre size of 265/70R16.
Does anyone have any experience with them?
Seems to be well reviewed on other forums. Price is certainly a factor.
- Been here a while
I run 285/75/16's on -22mm offset rims. There was scrubbing at the back of the front wheel well but a bit of gentle massaging with a hammer sorted that out.
Had a 60mm bodylift and had a 40mm suspension lift when the 33's were put on. Is a lot higher now but I have no idea what the actual lift increase would be.
It's an auto and 3L really struggled with the 33's. So I put in a 3.8L and it's now spot on
- I'm new, be nice!
32" muddies under 2003 PA??
is it possible with only a 2" lift or should I stick with 31"s??
- Here and there
Hi all,
I just got given a pair of near new Kumho Venture AT 31x10.5OR15LT 109s tyres.
I currently have Nexen Radial AT 265/70R15 on my 2001 PA Challenger.
Q1/ Will the Kumho's fit without alterations.
if yes
Q2/ Can you run the different sizes at the same time, my fronts are fine but backs getting down a tad.
if yes
Regards
Rich
Rich
You can't run different sized tyres. If used in 4wd the different sizes will destroy the driveline unless you have a centre differential.
Q1 - Yes, they will fit.
Q2 - No, you can't run different sized tyres. As said above, the moment you engage 4wd with different sized tyres, the driveline will begin to wind up and something will eventually give. In an emergency if you have no other option and you remain in 2wd only then you could do it to get you home. It may also affect your ABS ( if you have it) as the sensors may pick up the wheels rotating at slightly different speeds if there is a big enough difference in rolling diameter.
Nathan
Nathan
- Here and there
Thanks for the replies guys, much appreciated.
Will try sell the Kumho's or find some one who wants to do a swap.
Regards
Rich
Rich
- I'm new, be nice!
Challenger BIG TYRES AND LIFT
G'day guys new to the forum and keen on getting a PA challenger.
Just wondering how they would go with a 2" body lift + 2"suspension lift. What else needs to be done other than fitting new shocks, springs, torsion bars and body blocks? Is there a bit of mucking around to to install both. Also how does the PA go with 33's not too worried about fuel however don't want it to be a total slug. Would 33's fit under a 2 inch suspension lift or do I need the body lift aswell? All up I'm looking to do quite a bit of modding if I got one. Final goal is to have a setup which will handle cape trips, beach driving and general 4x4 play. Any recommendations would be awesome.
Cheers guys!
Cheers guys!
TB45T patrol, 400HP at the wheels
Need a new rig that doesn't drain the wallet...
- Been here a while
Re: Challenger BIG TYRES AND LIFT
Easiest way is probably to swap your TB45t Patrol with my Challenger and cash
Mine is the green one up a few posts.
- I'm new, be nice!
RE: 94 MJ Triton Ute Sunraysia Rims
Hi Guys,
Needing a bit of technical help here, I have a 94 MJ Triton Dual Cab and im wanting to put sunraysias on it, im thinking 15X7 or 15X8 and im wanting to go a 31" x 10.5 Tyre, just wondering what the best offset of rim is, I wouldn't mind to get the wheel track a bit wider but not ridiculously protruding out of the flares that are on the guards.
Thanks in advance for any help...
