Generation 1 Pajero NA - NG Models 1983 - 1991
hype
Re: Generation 1 Pajero NA - NG Models 1983 - 1991
Unread post by hype » August 8th, 2012, 11:07 pm
No ideas? :)
TUFF_80
Unread post by TUFF_80 » September 4th, 2012, 12:09 pm
A little update on my 89 Pajero Shorty. Removed sidesteps.
In the process of swapping motors at the moment, new motor is just a 2.6 petty as well but runs heaps better then the one in it. Also scored some extractors. :twisted:
HZJ80 - Safari turbo kit(8PSI), 3" straight through exhaust, 2" lift, 33's.
HDJ80R - 3" exhaust with muffler, 3" lift, 33's, extended diff breathers.
TUFF_80
Unread post by TUFF_80 » September 8th, 2012, 10:15 am
New rear bar... Needs some TLC and need to relocate my tow point.
Laidley 62 Series
Unread post by Laidley 62 Series » November 13th, 2012, 10:45 am
Hi All,
A stranger on here in Pajero but a friend had a Pajero which failed roadworthy so it went to the wreckers, don`t ask , but a new set of front shockies were purchased for it as well as a new starter so I have these to sell.
The shockies are Gabriel Ultras model no. G63418. These are brand new still in unopened box, they are for sale to best offer plus postage. These may fit other makes and models but I don`t know which ones.
Also I have a brand new starter for a V6 in this model, this will also fit this motor in a Magna I am guessing, it has never been installed in the vehicle and is still in the box it came in when purchaser from a supplier in Redcliffe. Once again best offer plus postage.
I am located in Laidley south east Qld and they can be picked up here or at Goodna in Ipswich Qld.
They are of no use to me so maybe one of you guys might need a new parts.
Happy Trails.
David.
My Karma ran over my Dogma.
josh_pajSWB
Unread post by josh_pajSWB » November 19th, 2012, 1:25 pm
Hey guys I have a SWB Pajero that is currently out of rego
As I am looking at getting it back on the road I need to fix it back up
Looking at the body I can see there is a lot of rust so I am in need of a new shell
Does anybody know where I could find a SWB Pajero shell with minimum rust?
Any help would be great thanks
1984 model SWB Pajero wih 31x 10.5x 15 muddies on back and 1997 GLX rims on the front
internally standard 2.6l, with custom exhaust system and custom airbox
2in shackle lift and wound up torsion bars
great fun and only owns me $200
cruisn06
Unread post by cruisn06 » December 14th, 2012, 9:43 pm
neilsonleif
Unread post by neilsonleif » December 28th, 2012, 10:21 pm
hey matt it sure looks shiny.... did u polish it or is that due to great photography????
You can't make ice cream from pig *****!!
cruisn06
Unread post by cruisn06 » January 3rd, 2013, 11:53 pm
A bit from column A, a bit from column B... haha
offroadwasigned by Cruisn, on Flickr
siddo
Unread post by siddo » May 29th, 2013, 8:25 pm
awesome thread and photos guys!!!!but
noticed that some pajeros have winches on their alloy bars. i didn't think it possible but just thinking if its possible then maybe i can mod my alloy bar. if anyone can point me in the right direction that would be awesome!.
going camping soon so hoping to add some photos of my turbo wagon
ryan
LordMayhem
Unread post by LordMayhem » May 29th, 2013, 8:41 pm
you need a steel winch craddle behind the alloy bar mate
grumpygramps
Unread post by grumpygramps » May 29th, 2013, 9:42 pm
Hi siddo,
Although I had an 85 Pajero It never got to have a winch but my NL did. I had an alloy Bocar bar and I fitted a winch. On the NL chassis there are 2 25mm punched holes on the inner side near the end of both rails. I cut shafts out of 25mm round that were shorter then the width of the chassis rails and drilled and tapped them 12mm. I welded a nut on the other end. These sat in the chassis holes. I then welded plates across the ends of a piece of heavy channel iron with the correct hole centres and this sat between the rails and was bolted there using 8grade high tensile bolts. From memory I bent a cheap spanner to get at the rear hex. My winch had synthetic rope so I cut a hole to suit the facia plate in the bullbar and ran 6mm aluminium behind along until the bar bent to shape the car. This was bolted on with 6mm ss bolts, washers and nyloc nuts. It all worked well and never let me down . Hope this helps. Regards Tony.
siddo
Unread post by siddo » May 30th, 2013, 5:10 pm
ok thanks guys. that will help heaps
ryan
cruisn06
Unread post by cruisn06 » June 27th, 2013, 4:52 am
Where is the gen 1 lovin guys? more photos!!!
Me and my brothers rig.
MKI DUO by .:FoRuM56:., on Flickr
Urban Stance by .:FoRuM56:., on Flickr
smt92
Unread post by smt92 » April 21st, 2014, 9:00 pm
Hey guys,
My old man just bought a ng paj turbo diesel it already has a rear arb locker, tjm bar with a warn which, safari snorkel and a couple of other bits such as dual batteries. What would you guys suggest to make her a bit more capable? We are planning to put a front locker, decent set of muddies, roof basket, cupboard for the back, rock sliders.
Also what type of rims would fit? Wanting to go atleast 33"
Is there anywhere to buy rock sliders that would fit?
Thanks guys
magic999
Unread post by magic999 » May 7th, 2014, 9:06 pm
Hi guys,
Just picked up this nb and soon to head into the vic high country. Does anyone have some tips for keeping the water out of this air intake until i get time to buy a snorkel? I've had no experience with this set up before, only plan is tarp on the front. It already has diff breathers.
"Don't argue with idiots, they'll bring you down to their level and beat you with experience"
Return to “Pajero”
