range rover engine
churchy
range rover engine
Unread post by churchy » November 10th, 2009, 2:07 am
i had my p76 block drilled to take range rover heads but the guy at the shop said i should get the p76 crank machined down insted to soot the 3.5 block as it has shorter rods and will hold together better but i am woried it will have to much compression it is also going to be fuel injected any input would be appreciated thanks.
Anthony
Unread post by Anthony » November 10th, 2009, 9:34 am
Churchy Hi. It sounds as though you're getting into real technical territory with that motor , sorry I can't help with that stuff , but I do remember that 20 years ago that was the V8 motor to use in speed boats because of the HP they could produce .
If you are in NSW there is a wrecker out at Silverdale who mostly wrecks Rover 4x4's , they may be worth a call , "Land Vehicle Spares" , you can check them out on the I-net at Australian Land Rover Owners
2.5 td Paj. Very good down hills. Whenever you take your foot off the accelerator it immediately goes into "Sleep Mode".
mrbenwithag
Unread post by mrbenwithag » December 6th, 2009, 10:02 pm
from what im told the p76's have the issue down the bottom end.
theres a bloke on here who had a an old 2door with a p76 in it, later on down the build up he put 3.5 heads on it and ran the standard twin carbies. didnt have much bad things to say about it after.
so sounds like your onto a good thing.
Rampt Customs 4x4.
for bar work and more
http://www.facebook.com/RamptCustoms4x4
LandRover-Biohaz
Unread post by LandRover-Biohaz » April 22nd, 2010, 12:38 am
Churchy. Mate if your still having difficulties with this dilemma, give the bloke at Les Richmond Auto a phone call or email (Les Richmond Automotive) He is a Land Rover and Engine specialist
I love Julian and his '86 Rangie "Drangonfly"
v8lux
Re: range rover engine
Unread post by v8lux » September 10th, 2010, 10:47 pm
I just bought my first rangie, it's a 83 with a 5 litre rover engine in it. (p76 with 3.5 heads) not sure how they get 5 litres if it's got a big bore or bigger stoke anyone heard of this before?
BMKal
Unread post by BMKal » September 11th, 2010, 4:01 am
If it's a P76 engine - doubt very much that it's a 5 litre. The P76 V8 was 4.4 litre, and I seriously doubt if there was the capacity to bore them much beyond this. The only 5 litre version of the Rover V8 was used in TVR sportscars.
amtravic1
Unread post by amtravic1 » September 16th, 2010, 5:40 pm
I had a P76 engine I rebuilt to 5 litres. I had the liners pressed out the block bored, new liners fitted and (from memory) 202 Holden pistons fitted to suit the new liners. I just ran the standard ww Stromberg carb jetted to suit. The engine pulled like a train and almost had the same performance as my mates 350 chev in a landcruiser. Never had any problems with it.
GuyG
Unread post by GuyG » October 8th, 2012, 9:32 pm
My previous 2 door had a P76 motor taken out to about 4.6 and my current one has been taken out to 5L. Mated with the LT95 with the higher ratio gears is a great setup. Carby setup is always an interesting one. I used to have a manifold that had been modified to take the twin strombergs to replace the Holley as it was useless on steep inclines.
To run the twin strombergs, you're either going to have to fit manifold spacers with the rover manifold or machine the P76 manifold to take the carby's you are wanting to fit.
Return to “Range Rover”
