Post up your Rovers and their Specs
mrbenwithag
Unread post by mrbenwithag » May 14th, 2009, 10:33 pm
tpj77 wrote:Sorry i didn't get back to you sooner, I don't get on here that often.
I paid about $265 for a new mufler, Y-piece and RHS pipe which was $130 on it's own as the old one was rusted badly and needed replacing. a @ 1/2 was about $30 more than the 2 1/4 that I have on.
Trav
all good mate.
thats not too bad. im tryin to go the cheap (but not dodgy) way out of gettin a beta note from the old girl. the big cenre muffler in it now has a nice rust hole in it which really doesnt help.
where'd you get your locker and axles from???
mrbenwithag
Unread post by mrbenwithag » May 14th, 2009, 10:55 pm
zook4fun wrote:what did you do for $9 to get the flex?
hey mate, i spaced up the bottom shock mounts by about 2-3"
the shock pretty much has last say on how much drop you'll have. (theres plenty others that hold it back, but the shock is the main player.)
by pushin it up, it allows it to go down further.
but!
it limits your up travel. kinda like winding up the torsion bars on an IFS rig.
so if your gona do that, make sure you extend your bump stops so that the up travel is being stopped by the bump stop, not the shock. or you'll end up busting the shock. i was lucky, i just bent the pin of the shock.:D
next issue you might have is the coil leaving the housing at the top.(asuming yours are not retained at the top)
at first i just welded some 12mm bar on the side of the housing, but it would never seat properly and was really, really noisy when it did, and i ended up snapping one side off. im currently in the proccess of making up some proper dislocation cones. but i couldnt do that until i did the body lift coz there wasnt enough room between the body and coil housing.
the not so cheap way out is to buy longer shocks and coils.:thumb:
tpj77
Unread post by tpj77 » May 15th, 2009, 4:32 pm
mrbenwithag wrote:all good mate.
Locker, well from ARB at about $1200 plus fitting. Axles ate Hi-tuff and can be bought from then direct (Ph 0755304123) about $800 plus postage is a rough estimate. totla cost for the rear locker was about $2600 fited.
Front I got as a trade for some Rangie bits of similar value (about $600) and still have std fronts and have yet to break them (although only done 2 trips with the front locker in). Still for around $3300 inc. all the extras such as the HD line kit for the front locker (HD line kit was included in the cost of the rear one) I am locked both ends.
Trav
95 Disco ES- ARB bullbar 265/75 Bighorns, 2 inch lift and the usual stuff
PSI250
Unread post by PSI250 » June 10th, 2009, 7:40 pm
1986 Hiline
mild 3.9L
MegaSquirt ECU
R380 5 speed
Maxidrive lockers and axles front and rear
40mm body lift
3" coils
LRA long travel kit
procomp extended shocks
cranked and strengthened rear trailing arms
arb bars front and rear
LRA rear wheel carrier
Super Swamper Q78 on custom 15x8 rims
Warn high mount
Range Rover- 3.9L, Twin locked, High Mount, Q78s.
mrbenwithag
Unread post by mrbenwithag » June 10th, 2009, 10:59 pm
PSI250 wrote:1986 Hiline
mild 3.9L
MegaSquirt ECU
R380 5 speed
40mm body lift
3" coils
LRA long travel kit
Warn high mount
drools!!!!!:truck:
willy08
Unread post by willy08 » June 17th, 2009, 7:52 pm
hey guys
some beaut 4bys here
just wonderin if any of you disco 1 owners have tried puttin 245/75R16 tyres on your disco with a 2 inch body nd 2 inch suspension lift?
how did it go nd did u have to do any trimming or anything?
cheers Willy08
jeeptheone
Unread post by jeeptheone » June 18th, 2009, 9:50 pm
micka wrote:Here is my RRC, Bob - Blue Ol' Bomb.
Its an '87 Classic with a few mods.
All the usual gear: Winch, dual batteries, snorkel, sliders, uhf etc...
And some not so usual gear: 37" Maxxis Creepies, Longfields 30 spline CVs, Detroit Locker, ARB Locker, Haultech Holy Bushes, Scorpion Racing rear links, custom shock towers, RoverTracks 300m 30 spline custom axels front and rear, RoverTracks drive flanges and steering arms, Maxi-Drive track rod.
And some other stuff...
I thought that I reconised yours from somewhere when I last saw it at Travs place way back last year or so. You are only round the corner from me and I spy the Rangie everyday. Very nice rig.
JTO
mrbenwithag
Unread post by mrbenwithag » June 19th, 2009, 10:47 pm
willy08 wrote:hey guys
cheers Willy08
i suck with numbers, does 245 mean about 33?????
coz my old mans rangie wears 33's with 2" body 2"spring.
very minimal scrubbing. disco1 wont be too much different:thumb:
willy08
Unread post by willy08 » June 20th, 2009, 12:34 am
mrbenwithag wrote:i suck with numbers, does 245 mean about 33?????
245 is about a 31 i think
cheers for that
mrbenwithag
Unread post by mrbenwithag » June 29th, 2009, 11:10 pm
31's and you wont have any dramas with scrubbing at all.
my old man had 31's on his rangie before he lifted it and he didnt have a drama.
cant see discos bein any different at all.
Mikey0211
Unread post by Mikey0211 » June 30th, 2009, 7:05 pm
245 is the width of the tyre, it has nothing to do with the height......
eg:- 245 x 75 x 16
the width is 245 mm
the sidewall height is 75% of the width.. = 183.75mm x2 = 367.5
+ 16 " for the rim...
so 773.9mm... or 30.46"
Indy Hepburn
Unread post by Indy Hepburn » June 30th, 2009, 8:20 pm
mild 3.9L
MegaSquirt ECU
R380 5 speed
40mm body lift
3" coils
LRA long travel kit
Warn high mount
What an awesome looking rangie mate!, I bet it can go anywhere:thumb: for some reason I have a soft spot for old rangies:crazy:
if in doubt more right foot!
mrbenwithag
Unread post by mrbenwithag » July 1st, 2009, 12:38 am
Mikey0211 wrote:245 is the width of the tyre, it has nothing to do with the height......
eg:- 245 x 75 x 16
the width is 245 mm
i know what the last digits are, thats about it. lol
Grimace
Unread post by Grimace » August 13th, 2009, 12:21 pm
FLUFFY!!!
Gramaces 'POS' Round 3 - Stay Tuned!
timbocruiser
Unread post by timbocruiser » August 16th, 2009, 9:32 pm
heres my 86 rangie!
Return to “Range Rover”
