what size tyres on 88 range rover
xj33
Unread post by xj33 » May 21st, 2011, 8:01 am
i have just bought a 88 rangie and want to run 35" or 33" tyres what do i need to do to make these fit
thanks
PSI250
Re: what size tyres on 88 range rover
Unread post by PSI250 » June 5th, 2011, 4:55 pm
35s, 2" susp, 2" body, Cut guards & flares, offset rims then let the breakages begin!
For 33"s 2" susp or 2" body, cut guards & flares offset rims then slightly less breakages begin!
THis is a rough guide.
Trav Man
Unread post by Trav Man » July 2nd, 2011, 9:39 pm
I would go the 33's as less breakages as PSI250 was saying
mcguckiana
Unread post by mcguckiana » July 3rd, 2011, 11:13 am
Nah! Go the 35s if thats what you want, but be prepared to upgrade the diffs (4.11's and locker) and the axles to cope. CVs also if you have the cash. All this will cost you about 7-8 grand... Saves all the breakages though...unless you really flog it.
Angus
Return to “Range Rover”
