TD5 broken bearing stuck in timing chain cover
akister1
Unread post by akister1 » December 21st, 2012, 11:19 pm
does anyone know how to get a broken bearing case out of the timing cover. it was the bearing for the clutch fan. long story short bearing broke fan hit radiator, caseing of bearing still stuck in the timing chain cover.
Psimpson7
Re: TD5 broken bearing stuck in timing chain cover
Unread post by Psimpson7 » December 22nd, 2012, 9:41 am
How much damage is there?
The bearing is retained by a circlip, which you will have to remove, but it is still pressed in.
You will have to make some sort of puller to be able to remove it
I do have some pics of what it should look like and me removing an intact one but its probably not going to help in your case.
Do you have a pic of the damage?
Return to “Discovery II”
