what is the 4wd shift pattern 1996 disco?
DesertCruiser
Unread post by DesertCruiser » July 6th, 2012, 5:02 pm
My brother inlaw has a 1996 disco Manual. his 4wd gear shift knob is worn real bad and we dont know what the high low pattern as it seem to have 2 low's ??
anyone help, Its not the hardest question asked here! :lol:
Thanks .... Darryl
I like both kinds of bush,.... The Desert and the Rainforest
ERASER
Re: what is the 4wd shift pattern 1996 disco?
Unread post by ERASER » July 6th, 2012, 5:13 pm
from memory you have forward is high range back is low range, but then push the lever to the passenger side and it locks the centre diff and has same forward and back for high and low. Its been while now so i may be wrong
My Hilux
DesertCruiser
Unread post by DesertCruiser » July 6th, 2012, 5:17 pm
so ... for black top it's Drivers side which is NO diff lock? and forward for high range ?
ERASER
Unread post by ERASER » July 6th, 2012, 5:23 pm
youll soon know if it high or low range. When the centre diff is locked it should have a light come on on the dash.
My Hilux
ERASER
Unread post by ERASER » July 6th, 2012, 5:26 pm
its the othe way around, high in back and low is forward..
My Hilux
DesertCruiser
Unread post by DesertCruiser » July 6th, 2012, 5:31 pm
Thanks heaps for that,
I dont have the techo setup like this, and being wornout, we were guessing, mines an old landcruiser.
Again thanks for the reply.
Return to “Discovery I”
