disco 1 engine options......
bravoboy300
Unread post by bravoboy300 » April 15th, 2012, 9:42 am
Hi guys, I've been given a series 1 disco with the tdi motor but it has a cracked head.. any ideas what motor I should replace it with? Will the v8 fit? Or will another motor go in there? Have any of you guys done this sort of thing?cheers
garrycol
Re: disco 1 engine options......
Unread post by garrycol » April 15th, 2012, 1:57 pm
Why not just get another head - they come up on ebay all the time. 300 Tdi are relatively common but if it is a 200TDI this maybe more problematic.
Garry
bravoboy300
Unread post by bravoboy300 » April 15th, 2012, 3:00 pm
It's got 400,000 on it and I don't think the bottom end is all that strong...not sure if its the 300 or 200tdi....I'd like something reliable and my experiences with these are they ain't too reliable....
Kampa
Unread post by Kampa » April 20th, 2012, 2:15 pm
300TDIs can go strong for a lot longer than 400 000, but it needs to have been maintained properly
D1s came in a V8 version as well so it should go straight in
V8s are realllllly really thirsty though, but I guess thats what you get ;)
Have a look on aulro.com theres heas of great info on all options
Good luck
the daily one 1994 LandRover Discovery 300 TDI
the new one 1993 Toyota LandCruiser 80 series 4.2 Diesel
bravoboy300
Unread post by bravoboy300 » April 20th, 2012, 7:41 pm
Cheers, will have a squiz... Considering comp truck maybe.......
bravoboy300
Unread post by bravoboy300 » April 20th, 2012, 7:53 pm
Kampa, got No idea of the previous life, the first time it came into my work was beacuse the drive belt snapped and it was cooked....Its been sitting with a pot full of coolant for about 5 months now while waiting for the old owner to decide what to do.... shame it had a whole new cooling system done about 3 months prior to this, and new front and rear brakes....so i doubt the bore will be much chop....
KevG
Unread post by KevG » May 26th, 2012, 9:28 am
I have a 300TDi that came with a cracked head. Looked like it had been overheated, but not 'cooked'. The valve springs were a bit saggy, but everything else seemed OK. Put a new head, springs, valves, timing belt, radiator, hoses etc on and she runs like a dream now. Had about 300 000ks when the work was done, now just over 400 000ks without a hitch. I use it as a daily driver and weekend/holiday tourer.
If it is a 300TDi the it would be worth investing in a new head/top end if the rest of the engine isn't a complete mess. It would then be a case of making sure regular maintenance has been done and a close eye kept on the coolant and oil levels.
In terms of reliability - the 300TDi is a great engine, used in both the Discos and Defenders. Lack of maintenance causes problems with them. The pressurized coolant system and the funny way it works can be problematic if you don't keep an eye on the levels, but other than that they are generally a pretty good thing.
Return to “Discovery I”
