Injector pump leak
RRF
Injector pump leak
Unread post by RRF » February 17th, 2012, 1:58 pm
looking for a little help. i have 300tdi with a slight leak from the injector pump i have traced it to the plug or smaller bolt in the center of the plug that is in the middle of where the four outlet pipes come out of pump. if i remove this to replace the seal ring will it change and setting? And is there anything i need to watch out for when doing this? I know this is noob question but i have never work much on diesel engines. :petrified: Hope somone can help thanks
Return to “Discovery I”
