are these the right bits
marcusscott
Unread post by marcusscott » February 8th, 2012, 7:19 pm
got a 96 disco with door lock problem got to hold the door lock up to open the door i have heard this is pretty commen and is just a spring are these the right ones
http://www.ebay.com.au/itm/Land-Rover-D ... 1093wt_934
Disco_Balls
Re: are these the right bits
Unread post by Disco_Balls » February 13th, 2012, 7:21 pm
Looks to be mate ... I've been in need of a set of these for quite a while, the driver side door has been playing up for a while, just bein' lazy I guess.
Another thing to look out for and adjust while you have the door card off, is the door release mech, if you find it hard to open the door without ripping the handle from its home, you will need to adjust the threaded rod of the mech, its on like a ball jointed end, held in place by a clip, simply slip the rod off the end of the ball joint, wind the rod on, reconnect and voila! :thumb:
Cheers and beers! :drink:
Craig
OFFICIAL Mitsnisyota RECOVERY VEHICLE!
Return to “Discovery I”
