how economical is your jimny?
jim_uzi
Re: how economical is your jimny?
Unread post by jim_uzi » May 6th, 2011, 11:30 pm
Dorfl
That is massive tyres. I Have trouble fitting 31". do you have some sort of reduction gears? I know there is a guy in the UK that sells them for about a sheep sation.
Dorfl
Unread post by Dorfl » May 12th, 2011, 7:52 pm
Thanks for the interest guys,
Jimmy10
I'm running 80mm Tough Dog suspension lift & 50mm body lift (along with some wheel arch massaging with an angle grinder :D )
jim_uzi
replaced the transfer case with a Sierra transfer case with 185% low range reduction and a 25% reduction in high range
Rig is a lot of fun off road but not the most practical as a daily driver.
Jimmy10
Unread post by Jimmy10 » May 12th, 2011, 10:29 pm
Dorfl,
I am a bit jealous i have a 2010 Jimny so a body lift is out of the picture as its my daily drive and need to keep it insured. If its possible could you throw a pic up of your wheel arch? I'd like to see the line you chose to trim and and how it changes the look of the car. I like the idea of chopping guards to fit big tyres as it keeps the center of gravity low.
Fun Size!
zookable
Unread post by zookable » February 12th, 2013, 10:53 am
Old thread but anyway.
My 2008 zook currently gets 300km until empty ( after the light comes on ) :(
I have 215/75R15 BGF AT's, ARB Bullbar, 9500lb winch, roof racks, basket and custom rear draws.
2008 Suzuki Jimny,
3" Procomp Lift
30" BFG KM2's
ARB Bar, Winch, Snorkel.
mediumaus
Unread post by mediumaus » April 3rd, 2013, 8:02 am
I have a nov 2011 jimny and I find I get around 420km to a tank stock standard.
zookable
Unread post by zookable » May 8th, 2013, 3:42 pm
mediumaus wrote:I have a nov 2011 jimny and I find I get around 420km to a tank stock standard.
I need to loose some weight lol :rolleyes:
2008 Suzuki Jimny,
3" Procomp Lift
30" BFG KM2's
petermountainhick
Unread post by petermountainhick » November 16th, 2014, 2:59 pm
I'm new, be nice! Posts: 1Joined: October 29th, 2014, 8:55 pm
Fuel consumption for Suzuki Jimny.
Hello to all. My name is Peter and I recently purchased a Suzuki Jimny in the Philippines. It is a 2004 model Automatic Hard Top in good condition with 74000kms on the clock. My major problem is that i am only getting 5kms/lt or 20lts/100kms. I know that I should be getting at least double this in fuel economy. I have replaced the spark plugs which appeared slightly burnt and also a small rubber cap on the fuel return canister that was faulty. But to no avail. The vehicle runs well whilst travelling but has an intermittent miss when hot and idiling. Prior to replacing the the rubber cap on the fuel return canister there was a strong smell of petrol coming from the engine. The cap replacement stopped that smell to a large degree but there is still a slight smell of petrol there when the engine is hot and idiling. Can anyone PLEASE offer any suggestions as to what may be causing this very poor consumption or where I should begin to look.
Return to “Jimny”
