jimny steering wobble - could the hubs be causing it?
jimnyhelm
Unread post by jimnyhelm » April 14th, 2014, 1:03 pm
Hi i just had a 2 inch lift on my 2008 Jimny and has this steering wobble now, took it back to the place i had it done and they check it and told me that the hubs had a lump in it and that is what causing the wobble. it only wobbles at 80 kms, i read about the king pins and shims could the hubs be causing the steering wobble.
jacobdoddson
Re: jimny steering wobble - could the hubs be causing it?
Unread post by jacobdoddson » May 8th, 2014, 3:10 pm
no not the hubs go to auzook and read on the issue its well documented and alot of people have had this issue as well as my
self
http://auszookers.com/forum/viewtopic.p ... es#p819224
Doddles
Unread post by Doddles » June 12th, 2014, 12:47 pm
jacobdoddson wrote:alot of people have had this issue as well as myself
I'm pretty sure in you're case it's actually the driver
Return to “Jimny”
