1991 vitara - any motor ideas for a diesel conversion?
darren94
Unread post by darren94 » November 24th, 2014, 1:14 pm
Hey guys, I have a 1991 vitara that I am looking at doing a turbo diesel conversion in. Just looking at ideas on a good motor to use and has anyone done this.
Cheers.
Darren
darren94
Re: 1991 vitara - any motor ideas for a diesel conversion?
Unread post by darren94 » May 23rd, 2015, 10:02 am
Bump
vk3aif
Unread post by vk3aif » May 23rd, 2015, 7:08 pm
Daihatsu Rocky maybe?
typhoeus
Unread post by typhoeus » May 25th, 2015, 4:47 pm
there is not a lot that will fit in the space available, euro cars are likely to be more efficient, but possibly more expensive. BMW and VW make a 2ltr,Holden cruise make a 1.4 ltr turbo deisel and a 2.o ltr but they are new front drive. Suzuki make a 1.6 diesel for OS markets, that might be easy to fit if you can get one, or check here for more ideas
http://www.rocky-road.com/samurai-diesel.html
4wd Hobbit
Unread post by 4wd Hobbit » May 25th, 2015, 9:22 pm
Consider a Freelander L series 2 litre (this is the earlier diesel to the BMW TD4 CRD diesel that was also fitted). Is pre CRD - is electronic but the electronics only control the timing of the fuel pump. It is a tough no nonsense engine. I had one in a Freelander and still going strong with 300,000km on it.
Should be cheap to find one - often you get the car thrown in as well so will have the ECU and loom.
You could also try a current Vitara diesel but it would be complex and expensive.
Return to “Vitara / X90”
