Busted Front Diff in 94 vitara!!
jaymills5
Unread post by jaymills5 » June 29th, 2011, 10:56 am
Hey guys,
i was out playing yesterday and got a little carried away and well i blew my diff housing up, im wondering if anyone knows if you can put the sierra diff in the front as they are still instead of alloy which i have heard is a common problem in the vitara? any help would be appreciated thanks guys!!
stufftheIFS-
Re: Front Diff in 94 vitara!!
Unread post by stufftheIFS- » June 29th, 2011, 11:58 pm
hi mate your vitara is idependant front end and the seirra is solid so you will have to do a solid axel conversion there are kits about for this but they are expensive . you woud be better fitting diff breathers and a bash plate
http://www.puresuzuki.com/sidekick_tracker.htm" onclick="window.open(this.href);return false;
ODA1
Unread post by ODA1 » July 1st, 2011, 9:56 am
look for a grand vitara housing - steel
christover1
Unread post by christover1 » April 19th, 2012, 8:39 am
If you have not broken the axle housing on the Vitara,
you can fit a Sierra steel diff centre/housing in,
but bottom of the Sierra diff needs a cut and reweld,
or crossmember/suspension support on Vitara needs cutting and welding.
Full steek GV v6 axle housing and diff housing is a good solution.
Return to “Vitara / X90”
