rough idling until warm
LJ, SJ
boynsie
Unread post by boynsie » September 25th, 2010, 2:42 pm
hi there
just outa the blue my zooki has the following issue
on cold start rough idling/missing
after a few minutes smooth idling
but while driving soft jerking occuring
thanks
ashhole
Re: rough idling until warm
Unread post by ashhole » December 1st, 2010, 12:01 am
yer my mate has the same pronlem not sure wat it is though does any one else have that problem
VooDoo
Unread post by VooDoo » December 1st, 2010, 12:16 am
Plugs or leads.
When warm they work better and dont arc out as badly. Ive had a few cars do it
ashhole
Unread post by ashhole » December 1st, 2010, 10:20 pm
but it that it just plugs and leads
Angus
Unread post by Angus » July 17th, 2011, 7:37 pm
most likley your choke has sezied open happend to my 89 sj50 soft top just take the carby hat off and see if its open when cold
shepsx
Unread post by shepsx » July 18th, 2011, 1:18 pm
Choke should be closed when cold, open when hot.
SierraDan
Unread post by SierraDan » July 26th, 2011, 6:22 pm
drop the coolant and and refill then run with the heater on.
Tonkatruck176
Unread post by Tonkatruck176 » January 20th, 2014, 11:57 am
Yeah mine did it too so I replaced the leads and the plugs
And was still doing it and then I replaced the
Dizzy cap was still doing it
So I took off the whole carby and played around lookin at things
And moving thiings to find out what was wat
Put it all back together and it worked
Dunno what I did but I fixed it haha
It's all fun and games till some one flys off the 4x4
hey it might be an suzuki but ill go places u wont
loch7791
Unread post by loch7791 » January 21st, 2014, 11:21 am
Its the auto choke... needs to be closed when warming up and open when at operation temp, I'd say its seized....
loch7791
Unread post by loch7791 » January 21st, 2014, 11:22 am
maybe even turn the idle up around 800-900 rpm if it hasn't already been done.
Tonkatruck176
Unread post by Tonkatruck176 » May 25th, 2014, 3:35 pm
i did that seems fine now so im happy
Return to “Sierra”
