Differences between Sierra and LJ's???? Experts needed!
- Need to get out more
Hi guys apart from body's whats the detailed differences between a Sierra, Narrow Track, Wide Track and a LJ Suzuki?
- Been here a while
Re: Differences between Sierra and LJ's???? Experts needed!
Don't quote me as I'm far from knowledgeable on the LJ. But many parts can be shared from the NT and WT sierra's except the obvious like bullbars and parts where the narrower body comes into play. Where as the LJ as far as I'm aware shares very little in parts or anything else. Most times when I get a part number for my sierra the part numbers are usually the same for the NT and WT sierras or can be interchangable but completely different for the LJ. Also the gearing is lower to support the smaller engine the LJ has, I think they were a little 350cc 2 stroke. Hope this helps in some way. Although I find it weird you asking Indy as you have been around the forums as long as the hills
Yeah but only new to LJ's mate
- Been here a while
Have just recently acquired one!!! I don't know much about them but it would be a fun learning curve, little beasts.
- Here and there
There are ALOT of differences from diff ratios to the engine/gearbox/transfer mounts/flanges etc etc etc
Your best bet and source of info would be www.AusZookers.com
There are quite a few knowledgeble guys on there and will answer all of your questions but try to do abit of reading first
