99 nissan terrano 2 2.7 tdi
Terrano, 720, X-Trail
turbo 1hz
Unread post by turbo 1hz » August 19th, 2010, 10:38 am
just purchased a 99 model190000klms for my missus got it for 70000 which for its condition i thort is cheap the rest on carsales are like 9000 or 10000 with more k's, i was surprised how they go i thort theyed be more slugish. it is in mint condition we brought it off an old guy and he had brought it of the original owner who was also old.
now we are going to use it for a trip to the cape next year so im going to stat building it up like draws fridge slide spotties maby 30's or 31's roof rack snorkel.
has any one done this befor to a terreno:drink:
YNOT
Unread post by YNOT » August 19th, 2010, 9:29 pm
Have a look at members rides/rigs or 'the shed'. Plenty of Terrano's and Pathfinders in there.
Tony
offroadjack
Unread post by offroadjack » August 19th, 2010, 9:52 pm
hmmm... you better upgrade your waterpump mate! these terrano's are made for the european climate! they overheat real quick in hot conditions!
if you wanna do a trip to the cape get a big radiator made up and get your hands on the "right" waterpump!
little motor, turbo, gets hot quick! tipical nissan problem.
other then that, a very nice little rig!
[b]should change my name in "ROLLOVAJACK"[/b]
turbo 1hz
Unread post by turbo 1hz » August 21st, 2010, 7:02 pm
yeh was thinking pwr radiator. im pritty sure the water pump has been changed to a navara one on just going off what the fella i brought it off are the navara ones better?. where i live there is a fairly long range to climb to get to the top and it doesent get hot coming up, where as my 4.2 turbo gq patrol will start to and its intercooled and has a Fn big pwr radiator. aswell as piro and ***** so i watch it
turbo 1hz
Unread post by turbo 1hz » August 25th, 2010, 9:51 pm
well started building draws for the back ill post pics when i find my phone cable dovlewaky that goes to the laptop. also started installing uhf. now i need spooties and snorkle, already have dual batteries
goody59
Overheating
Unread post by goody59 » August 26th, 2010, 4:22 pm
offroadjack, Not sure if the water pump is the issue. I have the 98 Turbo diesel Terrano 2. Had the overheating issue occur once on driving up the Billygoat track into the High Country in Eastern Victoria a few years back.
My take is the viscious clutch fan stops working after certain revs because the stock set up believes at that stage you are going fast enough for air flow to be produced by vehicle speed v's fan usage. That does not make sence for a 4x4 as engine speed does not equate to vehicle speed. I have not done this yet but I feel the fix would be to remove the fan and add a large electric fan activated by temperature with a manual switch too. A Davies Craig set up that also has fan activate with the aircon swithed to on as well. Am out on the right track here or have I got it wrong? It is a very capable 4x4 other that the overheating issue.
offroadjack
Unread post by offroadjack » August 26th, 2010, 7:50 pm
trust me, we've tried everything to fix this prob. on this trade in! the waterpump did the trick!
goody59
Unread post by goody59 » August 29th, 2010, 1:10 pm
What water pump fits into the stock 99 Terrano 2?
ben_al69
water pump
Unread post by ben_al69 » August 29th, 2010, 5:00 pm
hey guys
ive done the water pump and put a davies craig fan instead of the clutch fan. water pump is a navara pump. trust me, it makes a HELL of a difference!!! plus got more power without the fan pulling on the motor all the time.
ps. i have a terrano 1 1990 but same td27 without intercooler
turbo 1hz
Unread post by turbo 1hz » August 30th, 2010, 8:58 pm
here guys heres some pictureImages of what ive done so far
turbo 1hz
Unread post by turbo 1hz » August 30th, 2010, 8:59 pm
turbo 1hz
Unread post by turbo 1hz » August 30th, 2010, 9:00 pm
turbo 1hz
Unread post by turbo 1hz » August 30th, 2010, 9:01 pm
turbo 1hz
Unread post by turbo 1hz » August 30th, 2010, 9:03 pm
some pics of my power for lights on the left and the one at the back will be for the fridge. and thats a uhf my mate gave me for free to put in the terreno hope you like
goody59
Unread post by goody59 » August 31st, 2010, 1:17 am
What model Navara water pump fitted? What size Davies Craig fan did you use? Is that fan mounted in the shroud of original fan as a 'pusher' type? Can you send me some pics to goody59@aapt.net.au. This sounds like exactly the mods I need for my 99 Terrano 2. Did you do the work yourself? How hard was it to change out water pump and to take existing fan off and fit electric fan?
Return to “Other”
