Terrano/Pathfinder Technicial Specifications, Info, & Advice
WD21
Re: Terrano/Pathfinder Technicial Specifications, Info, & Ad
Unread post by WD21 » July 24th, 2013, 4:29 pm
Front Rotors: DBA/PBR/ACDR/RDA 624
The DBA catalogue says the Terrano before 92 ran a 621 rotor, and after 92 ran a 618 rotor.
Both my 11/93 and 03/89 Terrano have a 624 on them, so I'd wager that every Terrano does - Check your rotor diameter!
Rear Rotors: RDA 7650, or Protex DR12181
Front Pads: Bendix DB438
Rear Pads: Bendix DB1175
New Terrano build!
WD21
Unread post by WD21 » June 19th, 2014, 6:33 pm
Power Steering Reservoir to Pump Hose
Mackay CH3291
Gates 02-1190
New Terrano build!
WD21
Unread post by WD21 » July 22nd, 2014, 12:11 am
Universal Joints
Front:
Repco RUJ-1700 (Greasable)
Moog 446 (Non-greasable)
Rear:
Repco RUJ-2028 (Greasable)
Moog 393 (Greasable)
New Terrano build!
WD21
Unread post by WD21 » August 5th, 2014, 3:25 am
TD27T Engine Mounts
RHS - Kelpro MT8326
LHS - Kelpro MT8609
Listed for D21 Navara 1988-1992.
Fitment for WD21 Terrano 1989 confirmed. Years beyond 1992 may need to be checked for compatibility. I may get around to that at some point.
New Terrano build!
WD21
Unread post by WD21 » August 11th, 2014, 3:20 pm
Something I came across a little while back and haven't thought to post:
While looking at the specs for various fuel pumps on the TD27/T motor, I found that any fuel pump with an aneroid device (or "boost compensator") is set up from factory to compensate for up to 16.93PSI boost.
So you should be able to wind the boost up and leave the fuel pump adjustment alone, unless you want to run higher!
Usual disclaimer: Make sure everything is running right first, cooling system is in good order, etc.
New Terrano build!
WD21
Unread post by WD21 » August 11th, 2014, 9:01 pm
Sensors and threads for TD27/T
Oil Pressure port: 1/8" BSP
Water Temperature Sensor (gauge): M12x1.25
Water Temperature Switch (glow circuit): M12x1.5
Water Temperature Switch (emissions control, TD27T only): M12x1.5 (identical switch to glow circuit above)
RE4R01A Transmission (4spd A/T with lockup)
Forward/Reverse Pressure ports: 1/8" BSP
New Terrano build!
Return to “Pathfinder”
