Terrano/Pathfinder Technicial Specifications, Info, & Advice
daddydiesel
Unread post by daddydiesel » May 17th, 2009, 1:35 pm
try going through the side behind the wheel on passenger side rather than going from up top , use a band oil filter remover
Fishrman
Unread post by Fishrman » May 22nd, 2009, 8:05 am
Whats sort of motor preferably a diesel can I swap in for my TD27 in my 88 model?
I live in Queensland so would there be any mod plates going on?
mattBY89
Unread post by mattBY89 » August 24th, 2009, 1:45 am
For 2.7TD ~1990 engine:
Adjusted valve clearances on rockers to 0.356mm
No. 1 cylinder TDC, comp stroke, do valves 1,2,3,6
No. 4 cylinder TDC, comp stroke, do valves 4,5,7,8
Rattling engine now smooth as!
Is an easy job too :)
oops, been posted already.. although the manual i have specifies this different clearance to the previous post.
spoonano
nice truck!
Unread post by spoonano » December 21st, 2009, 12:12 am
Nice Terrano! good to see there are some out there getting mods, I have a non turbo 89 model 2 door, looks nowhere near as nice as yours with the chrome grille and bumper, recently had to do some paint repairs due to an acid rain incident, has a 1 inch suspension lift (sagged 2 inch lift apparently) and knackered shocks so they are first on the list of replacements, after that i'm planning exhaust/extractors to open up the top end (hah) a little bit.
really like the black 4 doors though! :) tempting to sell mine and find one but manuals seem to be few and far between.
Cheers for all your info.
Dom.
WD21
Unread post by WD21 » February 13th, 2010, 10:03 am
Disclaimer: I can not personally endorse this, and accept no liability whether it be damage, economy loss, or prosecution by fine.
Now that my arse is covered :)
For those wanting to scrap the EGR on their TD27/T, it should actually be quite simple.
Haven't done this myself, but have a copy of the service manual handy.
Looking at the inlet manifold on the water pump, there are THREE water temp sensors.
The one closest to the front is for control of the EGR system, and nothing more.
WD21
Unread post by WD21 » March 25th, 2010, 10:33 pm
In supplement to my post above - if it does result in an engine error code, simply place a 3.3kOhm resistor in place of the water temp sensor - will make the computer think that the sensor is there, but it won't meet the conditions to open the EGR valve.
ViBRatE
Unread post by ViBRatE » April 6th, 2010, 5:53 pm
Hey guys new to 4x4ing all together and i recently have bought my 1st fourby a 1987 2 door nissan pathfinder with a z24 engine in it. I would like to know what are the basic mods i should do to this car? Also i went to my local ARB for a 2inch lift kit they said the best they can do is a 30-40mm lift in the front and a 2inch coil lift in the rear. Reason i am askin is because i would like to fit some 31's under my vechile
Calyx_D21
Unread post by Calyx_D21 » April 6th, 2010, 6:56 pm
Whats a good later model engine to put in a 91 D21? i was thinking the 2.7ltr out of like a 97 terrano but, was told they aint that good or powerful??
WD21
Unread post by WD21 » September 6th, 2010, 9:09 am
For anyone interested in modifying their WD21 - It is possible to get a 3" body lift engineered in WA. I applied for it a long time ago and was granted approval in principle (just required an engineer's sign-off).
Went with a 2" lift anyway.
New Terrano build!
cmar
Re: Terrano/Pathfinder Technicial Specifications, Info, & Ad
Unread post by cmar » January 3rd, 2011, 7:12 pm
Post
Disconnect it, and see if you can run the car as per normal without an engine error code.
As I haven't tried this myself, I don't know if this results in an error code or not.
Give it a go though!
An alternative - same disclaimer- is to remove the vacuum line to the EGR module from the vacuum actuator asembly on the driver's side mudguard under the bonnet. Just trace it around to ensure you have the right tube. Plug the hose and then marvel in the lack of exhaust smoke, the vastly cleaner oil on your next oil change and the slightly improved economy. Please don't ask me for pictures as I no longer own the car and thus can't take any.
WD21
Unread post by WD21 » August 5th, 2011, 4:29 pm
New Terrano build!
NotoriousD21
Unread post by NotoriousD21 » September 29th, 2011, 3:35 pm
Awesome thread...
WD21
Unread post by WD21 » December 19th, 2011, 9:54 pm
Does anyone know how interchangeable the thermostats are for the 4cyl/6cyl Petrol engines and the Diesels?
We've determined that there are two thermostats available for TD27/T engines - which open at 76.5 degrees and 82 degrees, respectively, but I just found a Nismo Thermostat for (apparently) V6 Pathfinders (WD21/R50) that opens at 62 degrees.
New Terrano build!
WD21
Unread post by WD21 » May 9th, 2013, 7:20 pm
Radiator and Heater Hose part numbers (these seem to apply to both my 89 TD27T, and 93 TD27T):
Upper Hose:
Mackay CH3053
Gates 05-0821
Lower Hose:
Mackay CH2073
Gates 05-0832
Heater to Engine:
Mackay CH3663
Gates 02-0677
Engine to Heater:
Mackay CH3666
Gates 02-0678
Thermostat:
Tridon TT233-180 (82°)
Tridon TT2033-180 (82°, High Performance variant, 30% higher flow rate)
Gasket: TTG43 (Paper type gasket, sealing compound should be used)
WD21
Unread post by WD21 » May 23rd, 2013, 6:32 pm
There seems to be a lot of confusion about water pumps for the TD27T/TD27 motor.
I've read numerous things across a few forums and none of them actually make sense.
So, I will share what I have learnt from first hand experience:
Yes, there are two water pumps for this motor.
They are not a "normal" and "Australian spec" difference.
Up to 1992, the TD27 in the AU Navara was fitted with a fan hub with 135mm bolt spacing.
After 1992, it used a 143mm bolt spacing.
The TD27T in the Nissan Terrano (import) has always (as far as I can tell) used the 143mm bolt spacing.
Water pump with 135mm fan hub: WP3028
Water pump with 143mm fan hub: WP4130
These are Gates pumps made in China for Repco.
If you need to replace your water pump/fan hub, check the bolt spacing first! It may have already been replaced with the wrong one, who knows!
Also, if you're planning to replace it, it may be worth having a heli-coil kit handy! :irked:
New Terrano build!
Return to “Pathfinder”
