Terrano/Pathfinder Technicial Specifications, Info, & Advice
- I'm new, be nice!
Terrano MAF
I require a MAF for a Terrano TD27 (ETI) 1996 model, It's an Hitachi & the numbers on it are 22880 , 2J200 , AFH70-14. It has a 3 pin connector, or one that can be adapted !! also the voltage output ,Key on=1.0 volts, Idle=2.2 volts, & the rest I hope you good folks can help me with.
Thanks!
Thanks!
- I'm new, be nice!
MAF problem solved by this parts mob mailto:DDonnellan@cockramnissan.co.nz
- Been here a while
Nissan Pathfinder 2005 Factory Service Manual - 80MB
Nissan Pathfinder 2005 Factory Repair Manual.
RapidShare: Easy Filehosting
Click "FREE USER", there is a short wait till the download window appears, then click download when it appears.
This file is a RAR achive, needs winRAR or similair to open it, once it is open, it will prompt you for a password to access it(once), type "pdftown.com" without the ", then save it on your hard drive.
This pdf document has security, and will not allow you to copy, save, or edit, but it will let you print it!
Enjoy
Enjoy
- Been here a while
Nissan Pathfinder 2007 Service Manual - This is the current version of the above.
Same as above, Click "FREE USER", there is a short wait till the download window appears, then click download when it appears.
RAR achive file, use winRAR or similair to open, same password(pdftown.com) when its initially opened.
Enjoy!
Enjoy!
- Here and there
- Need to get out more
- I'm new, be nice!
Hey.
Im currently driving a 1994 V-30 R3M.
PULP. Auto. Nice truck, goes well, but 1 issue I hope you guys can help me with..
After quick sums, seems Im using around 25L/100km. Is this around par for a good mix of highway/city/dirt ??? As my last toy was a 1L 2-stroke 'Zuke, I cannot compare !!
Any thoughts or comparisons will be greatly apprieciated!
- Been here a while
Nissan Terrano I 2.7 TD WD21 Parts - Euro4x4parts.com
Pathfinder Parts (WD21) 1987-1995 :: CourtesyParts.com
The above links take you to OEM parts, part numbers and prices.
- Banned
- Here and there
runnamuk wrote:Hey.
Im currently driving a 1994 V-30 R3M. auto. Nice truck, goes well, but 1 issue I hope you guys can help me with..
I drive a 1990 manual 2.7T. I consistently get around 12l/100km and i don't think its tuned too well atm either.
Oh, and thats with 31" mud terrains
- Here and there
Boost gauge install ZD30
Hi has anyone installed a boost gauge on a 99 terrano Zd30, which vaccum hose is best to "T" into? i know if you stick it into the wrong place you wont get a true reading
- I'm new, be nice!
- I'm new, be nice!
- Here and there
runnamuk, my figures are for diesel.
1992terranoguy, i don't think you need to do that (assuming little variance between a 90 and 92 model). If access for a filter wrench is your problem then try a strap wrench on a flexy joint with long extension bar. I do it that way and don't have to remove anything else. It always leaks a bit because of the angle you have to tilt it on on the way out but I shove a towel under to catch it.
- Here and there
mixture screws
hi , if anyone still looks in here , please i need to know which screw is for the mixture on a terrano TD27 , there are two at the back that i can see , one is large at the top , the other is below this and is smaller , , also timing , can this model be adjusted by turning the body of the pump ?
settings for valves : , mormal temp exhaust and intake :
.25mm set number one on tdc (compression stroke ) and adjust 1,2,3,6,
turn engine to number 4 tdc(compression stroke) , and adjust the rest.
