Where is the Fan Speed resistor on 09 Navara?
ricksee1
Unread post by ricksee1 » February 11th, 2018, 3:11 pm
Hi guys , does anybody know where the fan speed Resistor is situated on 09 Navara, mine only works on 4 setting and cant get my aircon to engage on 1 2 or 3 settings, thanks for any help
hoyks
Re: Where is the Fan Speed resistor on 09 Navara?
Unread post by hoyks » February 12th, 2018, 9:34 am
Most are just down stream of the fan. Look under the dash, behind the glove box. You will see the fan housing and on the duct down stream of that will be a plastic rectange with a cable connected to it. Probably held in with 2 philips head screws.
Edit - A bit of googling and I found this:
http://www.navara.asia/showthread.php?s ... 928&page=2
He had to pull the glove box and cover off the bottom of the fan to get to it.
ricksee1
Unread post by ricksee1 » February 14th, 2018, 4:11 pm
Thank you, was told it was behind the glove box, took it off and now i have this pic ,what a great help cheers hoyks
Return to “Navara”
