Got bigger tyres? Come in here
Jakel
Unread post by Jakel » February 16th, 2012, 2:59 pm
G Day,
I read this from start to finish and it seams everyone with 33s on a D22 has done, 2inch lift (or 3inch), 2inch body and gaurd trimming. I understand the flex through its rage doesnt change with any lift so only a body lift gives body clearance or triming. I dont want to do a body lift but I am happy to get the 4inch out and do some triming.
Can you get 33s (285/75 R16) on with a 3inch lift and gaurd triming only, with minimal to no scrubbing off road?
Sargent80
Unread post by Sargent80 » February 19th, 2012, 7:46 pm
this my rig as it sits atm just deciding on lift and other ideas atm
285/75r16 with no lift minimum rubbing on road hasnt been flexed up in the bush yet
The Todd
Unread post by The Todd » March 16th, 2012, 10:49 pm
Daz1010 wrote:Hey fellas, just purchased some 33's maxiss bighorns for my d40. Miner scurubing on the inner guard at full lock but just trimed with tin snips as its just plastic. Hey nutt did you fit a 33 up in the spare wheel carrier as ive not replaced my spare yet going to buy 1 this week.
Gday Daz, know your post was a while ago but can I ask what lift you are running im about to put on a 2inch suspension lift and was hopping that would be enough for 33's ?
Todd
Daz1010
Unread post by Daz1010 » March 19th, 2012, 4:16 pm
hey mate, im running a 2inch ultimate suspension lift kit and a 2inch body lift. I don't think you'll fit them under with only a 2inch s/lift.
Cheers Darren
THE BLOKE IN THE KNOW WILL GO FURTHER THEN THE BLOKE WITH THE KIT.
The Todd
Unread post by The Todd » March 19th, 2012, 7:04 pm
Thanks Daz, looks like i will have to get a body lift as well oh well just have to convince the wife lol
Morticus
Unread post by Morticus » March 20th, 2012, 2:06 pm
Sargent80, Have you been up in the bush to test it out yet? Ive been hoping to do the same, just with a 2" body lift. Cant afford to get the suspension lift till after tax time, and need new rubber now. It would be nice to keep the stock bar too ( i dont mind cutting it a bit if i need too...)
The Todd
Unread post by The Todd » March 20th, 2012, 8:26 pm
Hey Sargent 80,
Nice truck, great to see you can get those tyres on without a body lift as I've just worked out their illegal in NSW, so suspension is only option and I really don't want to push that more than 2inches.
Would be keen to know what the rubbing is on, and do you think some minor panel work fix it.
Todd
Sargent80
Unread post by Sargent80 » March 27th, 2012, 6:53 pm
hey Todd they rub on the inside of the flares at full lock abit of chopping to the inside of the guard it at the bottom
im sure abit of cutting to the bottom lip will stop the rubbing but it hasnt worried me as it isnt that bad
also installed 2inch lift ill try and get a photo up asap
Sargent,
Sargent80
Unread post by Sargent80 » March 27th, 2012, 8:55 pm
here the photo with the lift in
thetoddles
Unread post by thetoddles » March 28th, 2012, 1:00 am
Thanks Sargent looks great.
Im due for the tyres now so hopefully next week i will get them on and see how it goes.
Todd
cno-87
Unread post by cno-87 » April 21st, 2012, 12:09 pm
Love the two D40's here Nutt and Sargant80! I have one myself and was thinking in the future to go bigger tyres like this, since i'm running 265/75/16 as it is on a 2" susp lift. Good too see some out there!!
Jakel
Unread post by Jakel » May 1st, 2012, 6:20 pm
I have fitted 33inch (285 75 R16) tyres to my 2009 D22, 3 inch lift, -20mm offset 16x8 rims, trimmed front and rear guards however both mud flaps can stay on. I have given it a few runs off road and have next to no rubbing. It will only rub with speed on full lock at 20psi or less. No body lift required. The spare also fits with a small bracket made to keep it away from the exhaust.
NIZ
Unread post by NIZ » May 17th, 2012, 12:56 pm
2010 D40 Navara ST-X - Got 75mm lift up front & 80mm on the rear - 265/70R17 MickeyT ATZ 4ribs wrapped around 17" XD Series Addicts +18mm offset, No scrubbing or chopping.
Mud Lover
Unread post by Mud Lover » August 14th, 2012, 9:31 pm
Jackel, I know its an old post but I was wondering if you could post up some pics of your trimming and where you did it. I'm not reall flash with the car maintence business and I can't figure out where the pervious photos of the trimming/bashing are taken. Any help would be much appreciated.
Cheers, Cookey
Jakel
Unread post by Jakel » August 15th, 2012, 3:52 pm
Mud Lover,
No worries, I will put these up on Fri 17th as I wont be near the Nav until Thurs night.
Return to “Navara”
