Got bigger tyres? Come in here
jvou
Unread post by jvou » July 27th, 2011, 7:09 pm
Do you have to go wider when you go bigger? I'd like more clearance , but Im happy with the width
ranger2452
Unread post by ranger2452 » July 27th, 2011, 8:16 pm
you can get 33x10.5 in some some brands
W.A .......whingers anonymous
tommy222220_0
Unread post by tommy222220_0 » July 27th, 2011, 9:29 pm
jvou, No you Don't have to go wider when you go bigger!
Yeah pretty sure you can get 235/85R16 (round 33" in old scale)
'05 D22 Navara STR
Shed: http://www.4wdaction.com.au/gallery/44852-toms-nav
jvou
Unread post by jvou » August 3rd, 2011, 8:52 pm
do people generally go wider as well?
My issue with wider is the power it robs. Aspecially with a 2.5 lt d22
NUTT
Unread post by NUTT » August 23rd, 2011, 8:19 am
Daz1010 wrote:Hey fellas, just purchased some 33's maxiss bighorns for my d40. Miner scurubing on the inner guard at full lock but just trimed with tin snips as its just plastic. Hey nutt did you fit a 33 up in the spare wheel carrier as ive not replaced my spare yet going to buy 1 this week.
Yes mate I did fit the spare in there, it's like it was made for it! Fits in snugly between above the diff cover and my towbar, could not fit a bigger tyre in that space.
How'd you go?
Daz1010
Unread post by Daz1010 » August 23rd, 2011, 7:19 pm
yeah mate got it under there.
Cheers Darren
THE BLOKE IN THE KNOW WILL GO FURTHER THEN THE BLOKE WITH THE KIT.
deano491
Unread post by deano491 » September 5th, 2011, 8:48 pm
g'day, i just fitted the 265/75r16's to my d40 nav. manual 2.5l, it has sucked a little bit of power out of it, but took it for a run on weekend and noticed it sucked the fuel, has anyone had the same problem not sure whether it was due to the windy conditions but wasn't pleased with the consumtion, can anyone help???
twon
Unread post by twon » September 6th, 2011, 6:50 pm
yeah i have fitted the same size to my d40 4l petrol have noticed a little difference in power but still preforms not that bad.As for fuel it has been worse now looking for any way to fix this problem
wepnvn
Unread post by wepnvn » October 4th, 2011, 8:20 pm
deano491, What tyre pressures do you run in the 265/75r16's??
deano491
Unread post by deano491 » October 4th, 2011, 11:00 pm
45 psi they are a/t, jst put a k&n filter in and has seen to ease it up somewhat.
tommy222220_0
Unread post by tommy222220_0 » October 5th, 2011, 10:23 pm
Pretty high, you must be carrying some weight.
search the "4 psi rule"
Run my muds round 35psi on road, 25-8 off.
'05 D22 Navara STR
troy.89
Unread post by troy.89 » December 2nd, 2011, 5:55 pm
Has anyone ran 35's but 11.5 wide? would they suck the power out of it just as much?
tevo
Unread post by tevo » December 24th, 2011, 8:06 am
Hi, I have a D40 with 5-6inch Calmini lift- OME shocks on front and Bilsteins on the back. Fitted by Macquirie 4WD.. Added 33inch Mickey Thompsons MTZ and all i had to do is cut the inside half of the front mudflaps off. All good now. They look good and are great in the muddy wetstuff although I do have to play the radio up a bit to hide the extra noise from the tyres.
cwolf
Unread post by cwolf » December 25th, 2011, 8:19 pm
g'day all i'm running a set of 235/85/16's on a set of 6" sunraysia rims that don't scrub at all on or off road.
only mod needed was to remove the front mud flaps, probably could've just trimmed them
but they where a bit knackered anyway..
They're on a 95 d21 with a 2" lift but wheels where on before the lift.
Noticed a bit of a difference in take off performance but it's tolerable.
thetoddles
Unread post by thetoddles » February 7th, 2012, 5:15 pm
NUTT, How much lift did you use to get them on there?
This is what im trying to achive at the moment
Return to “Navara”
