Got bigger tyres? Come in here
Daz1010
Unread post by Daz1010 » June 30th, 2011, 6:15 pm
Hey nutt, have you only got 2 inch of lift? As ive got 2inch body and 2inch suspension lift as im up for tyers soon was going to run that size.
Cheers Darren
THE BLOKE IN THE KNOW WILL GO FURTHER THEN THE BLOKE WITH THE KIT.
4.8GU3
Unread post by 4.8GU3 » June 30th, 2011, 8:59 pm
do they kill the power of the truck down low much?
joshy
Unread post by joshy » June 30th, 2011, 10:09 pm
negligible onroad, pretty average offroad.
Sas'd Navara..
viewtopic.php?f=27&t=30224
Tow/Tourer 76 cruiser
viewtopic.php?f=22&t=133211
Built not Bought
NUTT
Unread post by NUTT » July 1st, 2011, 9:42 pm
Hey Daz it's not really the lift that limits the overall size it's more about avoiding hitting the inner wheel arch pannels on full-lock, you'll be OK.
In a manual it will 'kill the power' more noticably, I don't notice it with the auto, it's still zippy taking off and it stays on boost while changing up gears. It still does a two-wheel stand-still on dry bitumen (although rotating pretty slow)
It's a little lower in the RPM's at 100km/h and with the roof racks loaded up when touring creating more wind resistance, she prefers to sit on 110km/h because it's got a few more RPM's therefor a bit more power to cruise up the slight hills on fwy's.
Low range- I can easily 'step on it' and chuck mud while going up a sloppy hill or in a mud pit, you would just need to get into the boost range to do the same.
Any more questions just ask ;)
4.8GU3
Unread post by 4.8GU3 » July 1st, 2011, 9:48 pm
Thanks Nutt, I sort of figured it would be noticeable. I hve 265/75's on my manual d40 and I noticed a bit of a change. I don't notice it now as I have gotten used to them.
I actually noticed the brakes more than the power. Was harder to pull up that is for sure.
Daz1010
Unread post by Daz1010 » July 2nd, 2011, 5:39 pm
Thanks nutt. I'll be buying that size tyre next.
Cheers Darren
Willo
Unread post by Willo » July 2nd, 2011, 6:50 pm
Hey guys, im planning on doing a 2" suspension lift and a 2" body lift to fit a nice set of 33x12.5 MTZ's.
what ive heard from a few tyre places is that the tyre will be destroyed by the bullbar and inside the guard. i think that is a load of ***** to start with and i just want some opinions from people who know what they are actually talking about instead of hearing from a "Professional" who probs drives a falcon or something.
I have a stock steel bar and i am willing to cut into it if i have to, in order to fit some 33's but not so keen on cutting inside the guard.
Willo
Daz1010
Unread post by Daz1010 » July 2nd, 2011, 6:55 pm
Hey wilo, is it a D22 or D40?
Cheers Darren
Willo
Unread post by Willo » July 3rd, 2011, 1:13 pm
D22 Single Cab 1998 3.2D
ben85n
Unread post by ben85n » July 7th, 2011, 1:36 pm
So has anyone Put a set of 32's on their D22 with the Std 16X8 Alloy wheels and found them not to scrub to much?
At the moment i have a set of well worn 265/75R16 ST's and they very occasionaly rub in the usual spots mentioned above in the bush.
Looking to buy a set of 285/70R16's (31.7inch) or 285/75R16's (32.8inch) and dont really want to change the wheels out. Happy to give the gaurds a little massage though, just dont want to be rubbing to bad on anything important...
The truck has a 2" suspension lift, but no bodylift...
Willo
Unread post by Willo » July 12th, 2011, 9:45 pm
What offset rim to u need to run on a D22 navara in order to keep it in the stock flares? my car was yellow stickered due to that and i dont want it yellow stickered again! plan on running some 32/11.5R15 or R16 after a long think about it.
decision is due to total travel, please tell me if im making a mistake and should actually stick with a set of 33/11.5 or 12.5R15 or R16.
Cheers guys, much appreciated coz i cant afford to waste any money coz it takes me like half the year to get tyres :D
tommy222220_0
Unread post by tommy222220_0 » July 13th, 2011, 1:33 am
16x8 ET+20 Rims
Will fit up to 35's (315/75R16) with 2" bodylift and front firewall clearancing like photo.
'05 D22 Navara STR
Shed: http://www.4wdaction.com.au/gallery/44852-toms-nav
Willo
Unread post by Willo » July 14th, 2011, 11:49 am
What does ET mean? so with a 2" suspension lift and 2" body lift u can fit 33's easy with some minor modification to the wheel arch?
tommy222220_0
Unread post by tommy222220_0 » July 14th, 2011, 8:56 pm
Willo wrote:What does ET mean? so with a 2" suspension lift and 2" body lift u can fit 33's easy with some minor modification to the wheel arch?
http://en.wikipedia.org/wiki/Offset_(wheel" onclick="window.open(this.href);return false;)
As for the trimming....
'05 D22 Navara STR
Daz1010
Unread post by Daz1010 » July 24th, 2011, 5:27 pm
Hey fellas, just purchased some 33's maxiss bighorns for my d40. Miner scurubing on the inner guard at full lock but just trimed with tin snips as its just plastic. Hey nutt did you fit a 33 up in the spare wheel carrier as ive not replaced my spare yet going to buy 1 this week.
Cheers Darren
Return to “Navara”
