Got bigger tyres? Come in here
Nemesis
Unread post by Nemesis » June 4th, 2011, 12:10 pm
Okay guys, we need your collective experience for some research on D21, D22 and D40 Navara's.
What we need to know is whether you have 33" tyres, or managed to squeeze 35" tyres under your Navara, any model.
If so, how much lift required to do the job? Spring lift? Body lift?
Unfortunately, knowing your brothers mates cousins second best mate apparently did x" for x tyres won't cut it. We need facts if possible, what lift fits what tyres, guaranteed.
Your proven advice will go a long way to helping a lot of people!
Nem ;)
tommy222220_0
Unread post by tommy222220_0 » June 4th, 2011, 2:25 pm
Here's some Info for the D22 (STR with flares)
Suspension Lift does not create any extra clearance due the it cycling between the bumpstops.
Offset is crucial in fitting larger tyres. STD 16x7's are +35ish If going to 16x8's +20 is recomended but you can get away with +0
31's are Standard - No mods
32's - require removal of front mudflap
33-35's - require 2" bodylift, removal of front mudflap and clearancing/trimming/bashing the lip on the lower firewall (see pic below)
here is a D22 with 35's (2" body + 3" suspension)
'05 D22 Navara STR
Shed: http://www.4wdaction.com.au/gallery/44852-toms-nav
strettman
Unread post by strettman » June 4th, 2011, 3:23 pm
Mate, I have an 06 D22 STR with cooper ST's 265/75R16 under it on the standard alloys. Not sure what these are in inchs though. Can tell you that the inside edge of the front mudflaps had to be trimmed, rear was fine though. The suspension is currently standard with no rubbing.
joshy
Unread post by joshy » June 4th, 2011, 4:44 pm
35's on 0 offset rims with 2" bodylift and minor trimming of the front as in pics above.
42" on -100 offset + 2" wheel spacers, front diff forward, rear diff backwards, custom suspension and a bit of guard chopping :D
Sas'd Navara..
viewtopic.php?f=27&t=30224
Tow/Tourer 76 cruiser
viewtopic.php?f=22&t=133211
Built not Bought
joshy
Unread post by joshy » June 5th, 2011, 9:16 pm
should add in the zd30 for the 35's, standard gearing was bareable onroad, made fuel economy noticibly better on the highway (lower revs for 100km/h) offroad for rock crawling was poor so i fitted reduction gears.
Sas'd Navara..
Built not Bought
ranger2452
Unread post by ranger2452 » June 5th, 2011, 9:24 pm
show off
W.A .......whingers anonymous
troy.89
Unread post by troy.89 » June 9th, 2011, 8:25 pm
what are reduction gears worth joshy?
brendan_h
Unread post by brendan_h » June 9th, 2011, 9:47 pm
tommy222220_0 wrote:Here's some Info for the D22 (STR with flares)
you stole my pic, thats my work there!
my nav on 33s on -12 16x8. minor scrubbing at full lock offroad but it doesnt bother me.
rear 2inch EFS springs, front just wound the torsion bars up till it looked right
trav298
Unread post by trav298 » June 9th, 2011, 10:13 pm
Ive got D40 Navara with 285/75R16's on standard rims. Have got Calmini 5" kit and it clears these easy absolutely no scrubbing.
joshy
Unread post by joshy » June 9th, 2011, 10:52 pm
ranger2452 wrote:show off
Only answering a question :rolleyes:
troy.89 wrote:what are reduction gears worth joshy?
They were about 1200 rockhoppers. calmini also do them.
Sas'd Navara..
Built not Bought
tommy222220_0
Unread post by tommy222220_0 » June 10th, 2011, 11:15 pm
brendan_h wrote:you stole my pic, thats my work there!
Sorry mate, was to dark outside to take one of mine.
Anyway good work.
'05 D22 Navara STR
bonzaman
Unread post by bonzaman » June 10th, 2011, 11:32 pm
strettman wrote:Mate, I have an 06 D22 STR with cooper ST's 265/75R16 under it on the standard alloys. Not sure what these are in inchs though. Can tell you that the inside edge of the front mudflaps had to be trimmed, rear was fine though. The suspension is currently standard with no rubbing.
google "tyre size calculator" 265/75r16=31.6x10.4x16
carter85
Unread post by carter85 » June 24th, 2011, 5:55 pm
how wide are the 35s on your nav joshy?
joshy
Unread post by joshy » June 24th, 2011, 7:44 pm
the ones in the pic were 13.5 wide
Sas'd Navara..
Built not Bought
NUTT
Unread post by NUTT » June 29th, 2011, 4:27 pm
I fitted Cooper STT's 285x75xR16 as pictured @ 15,000kms
I can hear the knobs touching the inside of the front mud guards at full-lock but never caused any damage, I didn't take mud-flaps off or do any panel beating. On my 2nd set of STT's now @ 70,000kms.
Return to “Navara”
