Hey Guys,
I was just wondering where about your oil pressure sits on the patrol?
ATM mine seems to sit around the middle and does not go a great deal over that. I vaigly recall it used to go a fair bit higher than that.
is that low pressure? what could cause that / is there anything can do to fix it?
seems to be running hotter than normal to, but that could just be summer..
Christian
Oil Pressure SD33 MK patrol
- Here and there
My Latest Project
[url]http://unkn0wnpatrol.blogspot.com/[/url]
Bit diferent to a s13, but it will still be fun.
- Here and there
- Been here a while
Mine'll sit a touch over mid way most of the time. On first start up and when its colt it'll be a good 2-3mm above the mid line. When its really hot it'll be just below it. Hope that helps.
87 MK Patrol. 2" OME + 30mm body, 31" ATZs on alloys/35" Simex ETs, dual ARB lockers, 12,000lbs winch in custom bar, Doof doof. Need more money!
- Here and there
- I'm new, be nice!
Re: Oil Pressure SD33 MK patrol
Mine sits around halfway most the time, when idling it'll drop down to about 1/3 of the way.
- I'm new, be nice!
Should sit halfway, my old motor read zero pressure for about a month before it blew up (oil starvation from clogged oil pickup)
- Need to get out more
Wheelzie1989
By using a Good quality detergent oil, regularly changed, an engine can never clog up the pickup cos it is being cleaned all the time.
Crook oil quality and only serviced once a blue moon almost guarantees failure.
