Gu patrol 4.2 tacho interface
4.2GUst
Unread post by 4.2GUst » January 5th, 2012, 2:39 pm
does anyone know where the gu 4.2 tachos pick up from ??
mine has resulted to fluctuate over the weekend was working fine until i left the drivers door slightly ajar and flattened the battery. i thought it may have been resolved with a newer battery as the glow plug light was coming on and off at low revs that has since stopped. there was a relay that was buzzing at the same time but that has stopped also . the tacho is still playing up
any ideas??
4.2GUst
Re: Gu patrol 4.2 tacho interface
Unread post by 4.2GUst » January 6th, 2012, 9:59 am
problem solved !
Unread post by Peter Aawen » January 6th, 2012, 10:20 am
OK, what WAS the problem??
I was just heading out to the car to see where the pick-up actually was - can't decipher the wiring diagram in the manual!!
4.2GUst
Unread post by 4.2GUst » January 6th, 2012, 11:19 am
turned out to be a loose earth on the intake manifold that i thouught i had done up but had only finger tight!
i ended up swapping out the ac relay and same problem so i knew it wasnt that so i traced back all the parts i have done since the intercooler install and that was it !
no problems now
will be getting it tuned soon
Unread post by Peter Aawen » January 6th, 2012, 12:19 pm
Bewdy!! You'll hafta bring it round sometime, maybe even convince me to go for a drive somewhere?!
Felux
Unread post by Felux » January 12th, 2012, 4:13 pm
where was the earth?
if you could send me a pic that would be great
4.2GUst
Unread post by 4.2GUst » January 12th, 2012, 7:40 pm
right under the standard intercooler it is the 2 wires that are bolted to the intake manifold that also has the bracket for the dip stick bolted to it
Return to “GU Patrol”
