Enquiries about lift for 35's
XJalltheway
Unread post by XJalltheway » January 14th, 2016, 11:01 pm
So I've done a bit of trawling through the Internet, and have come to the conclusion that to run 35x12.5 tyres on a GQ, a 2" suspension lift, plus a 1-2" body lift is the minimum amount of lift required. I'm planning on buying a Patrol, and just want to get everything planned out in advance, so that once I get it I can just go ahead with the mods. Now, I'm in Victoria, and I'm not sure of the legalities of running 35's on 3-4" total lift. I've heard some people say that it's illegal, whereas some people simply say you can't insure it. So what's the deal there? Obviously I don't want to be breaking the law with mods. A workmates of mine runs 35's on his GU coil cab with 2" suspension lift, and he hasn't had any dramas with it yet as far as I know. Will a 2" suspension lift plus 1-2" of body lift need to be engineered/certified? Sorry for all the questions, I'm just a person who way overthinks things in advance. Cheers
Rogers Cruiser
Re: Enquiries about lift for 35's
Unread post by Rogers Cruiser » January 14th, 2016, 11:56 pm
You can go 2 inchs up in suspension, and 1 inch up in tires (which is actually 2 inches in tire diameter up)
So legally (without engineering) you cna get to 33" tires under a 2" lifted vehicle.
If you can get an engineer to sign of on it then its legal, but I suggest you find an enginner befre you buy anything as most dont like hugly lifted vehicles.
Also body lifts are stupid
XJalltheway
Unread post by XJalltheway » January 15th, 2016, 9:03 am
Thanks mate
Return to “GQ Patrol”
