HJ75 indicator removal
Dicko_81
Unread post by Dicko_81 » August 6th, 2017, 1:04 pm
Giday folks my young fella has just bought his first 4WD - a 1992 Lancruiser ute, it is going in for a paint job and we need to remove the indicator assembly - got the lens off but can't see how to get the whole assembly off. Searched the electric interwebs without any luck. Help would be appreciated.
Brett Mcleod
Re: HJ75 indicator removal
Unread post by Brett Mcleod » August 8th, 2017, 5:49 pm
there are three nuts, you need to lift or open the bonnet and reach inside the guard, you will feel the three studs with nuts on them, undo the three nuts, they come off complete without needing to remove the lens :)
Dicko_81
Unread post by Dicko_81 » August 12th, 2017, 2:22 pm
thanks mate mission accomplished.
Brett Mcleod
Unread post by Brett Mcleod » August 12th, 2017, 5:20 pm
Dicko_81 wrote:thanks mate mission accomplished.
I only not long removed mine, i pulled the lens off too :) then found the nuts afterwards,
replaced mine with later model grill & indicators.
Dicko_81
Unread post by Dicko_81 » August 15th, 2017, 4:06 pm
Brett that looks sharp mate, may I ask where you got them from?
Brett Mcleod
Unread post by Brett Mcleod » August 15th, 2017, 10:17 pm
thanks Dicko,
got the grill and lights from eBay, lights bolt straight up to existing factory holes,
grill fitted with minor mods, ie i had to elongate the holes about 2mm on the two outer plastic mounting tabs at the top of the grill, then just had to bend the two lower outrigger brackets on the truck down 5mm, easily done by hand, I cut the factory plugs off my old lights & soldered them to the new lights to keep the harness factory plugs.
this is the store i got them from
http://www.ebay.com.au/itm/Toyota-Landc ... SwvjdZUo00
before.
after.
Return to “70 Series”
