Arb turbo timers?
07HiluxSR
Arb turbo timers?
Unread post by 07HiluxSR » May 12th, 2011, 9:56 pm
has anyone have a arb turbo timer in ther cruizer? are they any good?
pedrodepacas
Re: Arb turbo timers?
Unread post by pedrodepacas » May 12th, 2011, 10:05 pm
I had one mate. Was good for a while then started playing up with the times and stop button. (wouldnt turn off if needed)
stretch4x4
Unread post by stretch4x4 » May 12th, 2011, 10:05 pm
I would rather fit an exhaust temperature gauge and keep an eye on that..
I wanted a turbo timer but was put off because A) it is against the law to walk away from a running vehicle and B) if you were to be in a serious accident it might be hard for you or someone else to shut off your ute.
If you get an EGT gauge you can see how hard your motor has been working and let it cool appropriately or in quite a few circumstances see that it is already cool enough.
Image HDJ79R & Traxxas Summit
pedrodepacas
Unread post by pedrodepacas » May 12th, 2011, 10:11 pm
stretch4x4 wrote:I would rather fit an exhaust temperature gauge and keep an eye on that..
Good post^^^ and if it stuffs up like mine did. You will be finding it hard to turn off at all.
stretch4x4
Unread post by stretch4x4 » May 12th, 2011, 10:15 pm
Cheers mate. Yeah would be a bit of a pain to get it to shut off it buggered up.
Now was it the red wire or the green wire to cut..... :cool:
V8_td_cruiser
Unread post by V8_td_cruiser » May 12th, 2011, 10:24 pm
If it stuffs up, couldn't you just stall the engine?
stretch4x4
Unread post by stretch4x4 » May 12th, 2011, 10:26 pm
Yep that would be an option..
V8_td_cruiser
Unread post by V8_td_cruiser » May 12th, 2011, 10:31 pm
Not something I'd wanna be doing everytime I need to turn off the engine....
07HiluxSR
Unread post by 07HiluxSR » May 13th, 2011, 11:17 pm
but isnt it good for your turbo? instead of cooking it and then having to pay alot of bux?
pedrodepacas
Unread post by pedrodepacas » May 14th, 2011, 4:29 pm
V8_td_cruiser wrote:If it stuffs up, couldn't you just stall the engine?
My auto might be a problem.
V8_td_cruiser
Unread post by V8_td_cruiser » May 14th, 2011, 4:57 pm
Haha! I've been driving 70 Series vehicles for so long, the thought of an auto never even crossed my mind! But yes, I see that would cause a problem.
stretch4x4
Unread post by stretch4x4 » May 14th, 2011, 4:59 pm
07HiluxSR wrote:but isnt it good for your turbo? instead of cooking it and then having to pay alot of bux?
Well yeah....
But you can achieve the same thing by driving the last few kilometres keeping the revs a bit lower and letting it idle for a while while you undo your seatbelt and grab your wallet.
Using an EGR gauge you can see how much cooling you need as it tells you how hot the motor is so you know exactly when the motor is cool enough to shut off as opposed to a timer which has no idea how hard you have been driving.
Personally I would rather put my dosh into something that has dual purposes (can stop you cooking the motor while you are working hard) and use my brain a little more.
Hope that makes sense.
07HiluxSR
Unread post by 07HiluxSR » May 14th, 2011, 5:10 pm
ohks no worries:)
worthy
Unread post by worthy » May 14th, 2011, 5:16 pm
i have a timer, but it is very rarely turned on. I just cruise the last few kms, then wind up windows, turn radio down, grab my lunch(work days) etc. I dont see the point in using them all the time, and i'm thinking of removing mine altogether(installed when bought).
As for leaving it running and walking away, its a Toyota and you cant trust their handbrakes and never should.
2000 Prado 3.0LTD Lifted and Locked
viewtopic.php?f=22&t=87167
Have IFS, Will Impress
rv79ruiser
Unread post by rv79ruiser » July 19th, 2011, 11:04 pm
I've got an ARB timer, had it for 3 years and never had a problem. they are actually a Bogard timer just with an ARB sticker on it. turbo timer are definitely worth it, i'm a diesel mechanic and i have seen several shagged turbo's from no cool down periods.
Return to “70 Series”
