Turbo upsize help..any one who knows a thing or two about turbocharger give us a yell
messyjeff
Unread post by messyjeff » August 29th, 2010, 10:30 pm
hey there surf`ers...
I am looking for a bit of info about upsizing my current stock Toyot CT20 turbocharger to something with abit more Oooompth! want i want to know is;
can i put a bigger turbo on the 2L-TE surf motor?
will it be bad for my motor running a bigger turbo?
will it need better cooling?
what sort of turbo should i be looking for?
how big of turbo would be to much?
any information will be greatly appreciated guys. thanks a million...
[b]J-Spec SSR-X 93 model 2.4lt Surf, Black terra 3 King Wheels with 32" Maxxis bighorns, Turbo Timer, Boost Control [/b]
Instigator
Re: Turbo upsize help..any one who knows a thing or two abou
Unread post by Instigator » September 13th, 2010, 12:12 pm
Short answer is No.
You won't get any discernable benefits from changing the CT20.
Do some searching on the Surf forums for a more indepth answer.
http://www.toyotasurf.asn.au/forum/
http://www.hiluxsurf.co.uk/forums/index.php
Woodbutcher
Unread post by Woodbutcher » September 13th, 2010, 8:18 pm
Bottom line the CT20 is already to big for the 2.4 that is why ot does not come on boost till about 2000 rpm however a 3" dump pipe with a 2.5" exhaust will help improve it and you could then up the boost to say 10-12 psi
messyjeff
Unread post by messyjeff » September 16th, 2010, 9:46 pm
Rightio... its runs about 9 psi at the moment. i just bought a boost controller. any body got one of these on their surf? i wont hurt my motor by just simply turning the boost up a little every now and again will i???
Banno0025
Unread post by Banno0025 » September 16th, 2010, 10:02 pm
As long as you have a boost gauge and monitor it you will be right within reason.
I never went over 10PSI in my surf but it may have been alright with a little more, hard to say without the old trial and error method, which isnt ideal...!
On the same topic (sorry) is there another turbo that will bolt up nicely to the surf manifold? Like the TD04 or the Garrett T25 ? Just thinking about ideas for using the surf manifold and bits for a 3L
messyjeff
Unread post by messyjeff » September 16th, 2010, 10:06 pm
yeah true that but if i can upsize my dump pipe and exhaust for increased boost just simply turning it up should`nt hurt to much ey....
Return to “Surf”
