turbo surf
good old 60
turbo surf
Unread post by good old 60 » April 29th, 2009, 8:34 pm
wife just bought herself a 89 import turbo surf. just wondering what the first mod would be as flat to the boards 105kM i was thinking exhaust but maybe tune up from mtq would be a better start????
12ht, 11 psi boost, 35" cooper 2"body just waiting for 4" rhino kit to come.
GippsSurfer
Unread post by GippsSurfer » April 30th, 2009, 8:51 pm
tune up and make sure that every thing is in order....
check out the aussie Surf site... a wealth of info...
ToyotaSurf Australia Site
[align=center][b][font=Arial]1992 Hilux Surf 2.4TD[/font][/b][url]http://www.4wdmonthly.com.au/shed/index.php?content=all&chunk=arbu&user=2495[/url][/align]
894runa
Unread post by 894runa » May 1st, 2009, 9:37 am
Guessing it would be the 2LT motor.
On the Surf website there's a number of these that have overheated and cracked heads. So first mod I would do would be an aftermarket water temp gauge as the standard one has a few minutes delay in it.
WellsieTRD
Unread post by WellsieTRD » May 2nd, 2009, 1:14 pm
First of all, Oz proof it. Temp gauges and an Aus spec radiator is a good start. As for mods, winding up the boost a bit and a putting an exhaust is also a good place to start. Im using a Turbotec manual boost controler running 11psi (ecu cuts in at 12psi) and the performance improvement is noticable.
1989 LN130 Surf 2 Door, EFS Elite Front and Rear Shocks, 2" Coils ,32" Goodyear Wranglers on 15x7's, Exedy Solid Flywheel, Lightforce 170 Striker spotties, Safari Snorkel...more toys to come :D
"Some will like Surfs, some won't. Hell some even like Jeeps and Range Rovers"
good old 60
Unread post by good old 60 » May 4th, 2009, 7:26 pm
your right it is a 2lt non electric. just finised fitting the custome made 2.5" exhaust. it gave it a nice note and now will pull skin off a custard. next step is to have the cooling system checked by the local bloke i have not had 2 seconds to check the surf site but will make time. thanks for the imput. selling diesel engine parts i know what the symptons are and what causes alot of the problems with engines. will get a picture/ movie clip once i work that part out. cheers guys.
Return to “Surf”
