Toyota Surf 2LTE throttle sticking?
Phizinza
Unread post by Phizinza » January 27th, 2009, 6:16 pm
A mate of mine is looking at buying a 91 Surf with a 2LTE (170k on the clock). When you shift the throttle continues to go up when you take your foot off the pedal and put it on the clutch. Goes up by about 300rpm then drops like normal. The choke looking vac diaphragm and vac switch thing on the TB has been blocked off. Everything else looks good. Cable is free to move, TB moves freely too and has plenty of return spring. I was wondering if it could be something to do with the EFI pump and maybe the computer?
So basically is this a major problem? Easy fix? Expensive fix?
And anything else to look out for on these models?
He'll be buying it tomorrow arvo if he is going to buy it, so be quick please! :)
[color=RoyalBlue]83 Subaru Leone 4WD[/color]
Return to “Surf”
