1997 1KZ TE 185 FLASHING 4WD DISPLAY/ NO 4WD
stufish62
Unread post by stufish62 » September 28th, 2015, 9:19 am
Hi guys I have just removed the sensor from the transfer box and cleaned but no luck in stopping the flashing. Any ideas on fixing that and also as to why 4WD drive wont engage. I got no idea even where to start looking at this problem. Any help will fantastic.
skintguy
Re: 1997 1KZ TE 185 FLASHING 4WD DISPLAY/ NO 4WD
Unread post by skintguy » September 30th, 2015, 9:22 pm
New here too, and I have an LN 130.
For a greater Knowledge base, may I suggest you pose the same question in the relevant forum of www.toyotasurf.asn.au
Unread post by Peter Aawen » September 30th, 2015, 9:42 pm
There's a fair bit of info here on this Forum if you bother to look for it!! If you need a hand searching, drop me a PM, or try using google with 4WD action on the end of your keywords/search string. ;)
Return to “Surf”
