Having trouble removing axles from diff - any ideas??
Coco7
Unread post by Coco7 » April 17th, 2014, 10:43 am
Hi guys, as the title says i need help removing the axles from the diff of my ln130 surf. Ive gotten the drivers side out but i cant get the passenger side out. Ive undone the 4 bolts holding that whole half shaft to the diff housing and the axle and halfshaft have come out. but my problem is i cant remove the axle from the half shaft. Ive taken the clip of that holds the cog thing and taken the cog off, ive also undone the bolts holding some other flange on (theres 3 bolts). all i want to do is replace the outa seal cuz its leaking but i cant remove the axle from the half shaft.. Can someone help please???
Coco7
Re: Having trouble removing axles from diff - any ideas??
Unread post by Coco7 » April 17th, 2014, 4:23 pm
Well, for anyone else having these troubles, the passenger side needs to be pressed out. Due to a bearing and stuff
typhoeus
Unread post by typhoeus » April 18th, 2014, 4:53 pm
So, is it all fixed & running? . . Ill remember that if I have to do mine!
Coco7
Unread post by Coco7 » April 18th, 2014, 5:22 pm
Yea its all fitted and running. doesnt leak anymore thank goodness lol
Return to “Surf”
