94 Surf SSRX 1KZ-TE Limited Edition "DO YOU OWN ONE" ?
Toyholden
Unread post by Toyholden » December 2nd, 2012, 8:51 pm
G'day Surf owners :)
I would be ever so gratefull if someone could clarify a simple Question Regarding the Height of my SURF
I have been trying for most of Today to find out the FACTORY Height of my :
> TOYOTA SURF 94 MODEL > 1KZ-TE > 3.0LT > T/D > AUTO > Limited Edition > Wide Body > With 265/75R15 tyres
I am in need of Factory Overall Height, which is in the Owners Manual for this Model Surf in the SPECIFICATIONS Page
Under DIMENSIONS :thumb:
When i purchased my Surf i was given the 4Runner Owners Manual & the Specs in the Dimensions might not be the same as my Surf :confused:
A standard 4Runner with stock tyres says its height is : 1755mm code *1 - *2
A SR5 4Runner wide body with 265/75 R15's height is : 1775mm code *3
I need for my model 94 SURF with 265/75 R15 height :.......mm code *3 ????
Do you have the SURF Owners Manual ?
Can you Help me :thumb:
"DUCK"
FuzzyM
Re: 94 Surf SSRX 1KZ-TE Limited Edition "DO YOU OWN ONE" ?
Unread post by FuzzyM » August 27th, 2013, 1:53 pm
Im curious if anyone has one with an R151 manual box. Some (lots) research on the net suggests that pre 1996 surfs with the 1KZ had the R151F manual with a short input shaft. Whereas later 1KZ manuals had an R151F with the long input shaft. Or maybe an R150, very confusing information.
If I ever have the money I want to swap an R151 in to my lux to replace the weak W56 transmission, then supercharge.
The early R151's have the same input shaft as my box. Also the gear ratios in the R151 are better for offroad driving.
So much misleading information on the net! :(
1998 Dual Cab Hilux 2.7
Toyholden
Unread post by Toyholden » September 24th, 2013, 12:10 pm
No idea... I was under the impression that all the 94 Surfs with 1kz-te were auto's :o :lol:
Toddy Lempa
Unread post by Toddy Lempa » September 25th, 2013, 1:55 pm
Hey Duck,
Mate the Overall Height as per the Surf Manual is 1775mm (with 265/75R15's).
It's on page 158 of http://www.toyotasurf.asn.au/techsite/d ... Manual.pdf
Fuzzy,
I've got a 1994 1KZ-TE and it has an R151F manual trans as per the model plate on the firewall.
94 SSR-G Gold 1KZ-TE 3L Man, 31 10.5 16 Goodyear Wranglers, 2" Old Man Emu Suspension Lift, Free Wheel Hubs, Front Lokka.
Kenwood CD/JVC DVD, 2x LCD Screens, 2x Option Audio Amps, 12" DVC OA Sub, 6x9's rear.
Toyholden
Unread post by Toyholden » October 2nd, 2013, 11:28 am
thanks Toddy :thumb:
Return to “Surf”
