CV differences?
dirtfix
CV differences?
Unread post by dirtfix » December 28th, 2010, 11:33 am
Righto, i got a replacement CV off a mate of mine out of his 03 model Hilux and set about fitting it to my 90 model surf but i cant seem to get the outer spline to pull out through the hub assembly far enough to get the damn serclip to seat in the groove, even without the washer. So i am thinking that the later model CV may be just that couple of mm shorter. But short of pulling it all back apart again to check i thought someone on here might be able to help.
boof
Re: CV differences?
Unread post by boof » December 29th, 2010, 8:34 am
I was under the impression they were the same, possibly check with someone like Buddy as he knows Hiluxs backwards.
2014 FJ with a few mods
dirtfix
Re: CV differences?
Unread post by dirtfix » December 29th, 2010, 10:26 pm
I ended up taking it back out cause it was doing my head in. Turns out the seal that rests at the back of the hub is slightly different and looks to be shorter by only about 2mm. Got a replacement today and it fitted straight on easy as. So i guess there is very subtle differences. Apparently it fits when you use an older one in a newer rig but not the other way around. Either way its fixed now and i am a happy camper again. :thumb:
Woodbutcher
Re: CV differences?
Unread post by Woodbutcher » December 30th, 2010, 8:31 pm
Same CV if anthing it was the seal stopping you! put a bolt in the end of the CV and lever outwards while you fit the circlip
1990 Surf with a couple of Mod's
1UZ V8 (conversion done by me)
Coil SAS with 60 front diff (conversion done by me)
THE SHED [url]http://www.4wdaction.com.au/shed/index.php?id=5932&im=1[/url]
dirtfix
Re: CV differences?
Unread post by dirtfix » December 30th, 2010, 10:02 pm
Yep tried that. Only thong I can think of is maybe it was bent?
3dhilux
Re: CV differences?
Unread post by 3dhilux » December 31st, 2010, 11:52 am
it was shaneo cv so fair chance it might be bent. see if u can get a grove cut in it be a good spare also the 1 we sent up to u was out of a 99 model
drunken engineering
web wheeling since 2009
except toplux he's awesome
Woodbutcher
Re: CV differences?
Unread post by Woodbutcher » January 1st, 2011, 9:48 am
I still have 3 genuine toyota CV's here if you need them $50 each
dirtfix
Re: CV differences?
Unread post by dirtfix » January 1st, 2011, 3:23 pm
Thanks man, I will let you know when I break one. Notice I said when and not if. Lol.
Lux Wrecker
Re: CV differences?
Unread post by Lux Wrecker » May 7th, 2011, 8:21 pm
I could of told you that! :crazy:
Hylux Heaven / 4x4 Heaven 3/102 Harburg Dr, Beenleigh Qld 4207, NO LONGER WRECKER - http://www.facebook.com/HyluxHeavenPtyLtd
http://www.4x4-heaven.net https://www.dropbox.com/s/qfew5474gq93ky0/Hilux%20Heaven%20Monthly%20specials%20Febuary%202014.pdf
Return to “Surf”
