How Get Flex Cheap on a solid axle hilux
Dylan Grant
Unread post by Dylan Grant » February 8th, 2018, 7:19 pm
Got a 94 hilux and am look for ways to get cheap flex.
cuzza_wa
Re: How Get Flex Cheap on a solid axle hilux
Unread post by cuzza_wa » April 16th, 2018, 12:55 pm
How cheap? :P
Unread post by Peter Aawen » April 16th, 2018, 1:09 pm
Take some of the load bearing leaves out of the spring packs? That'll give more flex, at the cost of load carrying ability; and if you use the longer main leaves reset to a touch more curve, you might even retain the std static ride height! ;)
Return to “HiLux”
