Diff ratio question
LUX4WD
Diff ratio question
Unread post by LUX4WD » April 24th, 2012, 11:52 am
Hi guys, im running 33's at the moment but looking at 35's so obviously looking at going from 4.3's to 4.8's. Im a little bit confused thou as im running a rear arb locker at the moment. Does this mean for me to change to 4.8's will i need to change my locker? Probably a stupid question but have no real idea about diffs.
Any help would be great :)
MY LN106 BUILD - 35's, turbo, locked viewtopic.php?f=22&t=137103
Blackened
Re: Diff ratio question
Unread post by Blackened » April 24th, 2012, 12:13 pm
You'll just have to take the locker out of your current diff and put in the new one, really just an uninstall and a reinstall.
My Shed
http://www.4wdaction.com.au/shed/blackeneds-lux
1994 Toyota Hilux with a V8
LUX4WD
Unread post by LUX4WD » April 24th, 2012, 12:19 pm
Thanks for that, sounds straight forward! Is there much to fitting a locker? Big job or straight forward?
NZ LUX
Unread post by NZ LUX » April 25th, 2012, 7:58 pm
Would it not be a case of simply changing the crown and pinion gears? Leave the locker and carrier as it is.
cac
Unread post by cac » April 26th, 2012, 9:17 am
that's what I would have done NZ Lux.....
LN106 Hilux Project
LUX4WD
Unread post by LUX4WD » April 26th, 2012, 9:43 am
Thanks for your replies guys.... Would you have any idea on what that would set me back?
TOYOTANUTS
Unread post by TOYOTANUTS » April 26th, 2012, 12:43 pm
if your looking at selling your 33s let me know cheers bud
LUX4WD
Unread post by LUX4WD » April 26th, 2012, 2:52 pm
Will do mate... Probably wont be for a while but will let you know forsure :)
Return to “HiLux”
